[snappyHexMesh] SHM, poor snapping issue
Old   July 28, 2014, 10:08
Default SHM, poor snapping issue
Pål Grøthe Sandnes
palgroth is on a distinguished road
I'm currently trying to mesh a 45 degree bended pipe. but the snapping does not go as smoothly as I hoped.
I've seen that people have experienced similar behaviour, but I have yet not seen a solution to the issue. Any ideas?
Regards
Pål
palgroth is offline   Reply With Quote
Old   July 28, 2014, 21:04
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
I could spout off a few things to try, but without the geometry i would really be offering suggestions rather than a solution. Knowing that, try these:
  1. make sure your base-mesh is composed of cubic elements and not rectangular prismatic elements
  2. reduce the geometric size of your base mesh elements
  3. increase nFeatureSnapIter to at least 10
  4. increase the levels around your pipe (however it is already (3 3))
the first 3 should do the trick. Good luck.
chegdan is offline   Reply With Quote
Old   July 29, 2014, 03:05
Pål Grøthe Sandnes
Thank you for your answer. I found out that the problem is only introduced if "empty" patches exist in the base mesh.
Pål
CAMWA special issue on open-source numerical solver feixu2019 OpenFOAM Announcements from Other Sources 0 October 1, 2018 11:21
CAMWA special issue on open-source numerical solver feixu2019 SU2 News & Announcements 0 October 1, 2018 11:19
[snappyHexMesh] different sHM results on same geometry when everythin is in one or several stl-files. Laika OpenFOAM Meshing & Mesh Conversion 1 September 8, 2016 04:09
Convergence issue in natural convection problem chrisf90 FLUENT 5 March 5, 2016 08:30
[snappyHexMesh] SHM: feature edge snapping not conforming thab OpenFOAM Meshing & Mesh Conversion 3 November 26, 2012 14:04
