[snappyHexMesh] Fail to create boundary layers during sHM |
June 1, 2011, 05:24 |
farahidayu
Rep Power: 15 |
Hello all,
I am currently working on the external aerodynamics case for a car. Basically, I manage to do the snappyHexMesh However, eventhough I set the number of layers = 10, but, I fail to create even a single layer. I dont know what is the problem with my file. The part in sHM where I define the no.of layers are as below: // Settings for the layer addition. addLayersControls { relativeSizes true; //relativeSizes false; // Per final patch (so not geometry!) the layer information layers { car3 { nSurfaceLayers 3; } } // Expansion factor for layer mesh expansionRatio 1.0; //- Wanted thickness of final added cell layer. If multiple layers // is the // thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. //finalLayerThickness 0.0055; //absolute finalLayerThickness 0.1; //relative //- Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. //minThickness 0.0005; //absolute minThickness 0.1; //relative //- If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. nGrow 1; // Advanced settings //- When not to extrude surface. 0 is flat surface, 90 is when two faces // make straight angle. featureAngle 15; //featureAngle 30; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 3; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 1; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // Smooth layer thickness over surface patches nSmoothThickness 10; // Stop layer growth on highly warped cells //maxFaceThicknessRatio 0.0025; //absolute maxFaceThicknessRatio 1.0; //relative // Reduce layer growth where ratio thickness to medial // distance is large //maxThicknessToMedialRatio 0.0015; //absolute maxThicknessToMedialRatio 1.0; //relative // Angle used to pick up medial axis points minMedianAxisAngle 130; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations nLayerIter 50; } Hope someone could help me on this. The pics of the section cuts are as attached. Thank you. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
