[blockMesh] getting unwanted internal faces
Old   November 13, 2014, 01:57
Default getting unwanted internal faces
Arjun
Arjun Jayakumar is on a distinguished road
Dear all,
I am new to blockMesh utility. I have attached my domain with corresponding vertices numbering. I want to divide my domain in to four as marked in the figure.
for that following codes are used:
hex(0 1 2 8 10 11 12 18) (10 10 1) simpleGrading (1 1 1) //block 0
hex(8 2 3 7 18 12 13 17) (10 10 1) simpleGrading (1 1 1) //block 1
hex(7 9 5 6 17 19 15 16) (10 10 1) simpleGrading (1 1 1) //block 2
hex(9 3 4 5 19 13 14 15) (10 10 1) simpleGrading (1 1 1) //block 3
But i am getting two internal face, its orientation is (7 17 9 19) and (9 19 3 13)
I want to get rid of this internal face. Or help me with any other condition that will nullify the effect of internal face.
Arjun Jayakumar is offline   Reply With Quote
Old   November 13, 2014, 04:19
T. Chourushi
Tushar@cfd is on a distinguished road
Originally Posted by Arjun Jayakumar View Post
Dear all,
Attachment 35071
I would rather create blocks out of nodes (9,19) and divide block 0 and 1, similar to block 2 and 3.
Anyways, try defining your Boundary Conditions like this,
defaultFaces
type empty;
Re-run your case, I hope it will solve your problem.
Best Luck!
Tushar@cfd is offline   Reply With Quote
Old   November 13, 2014, 05:02
Arjun
defaultFaces
type empty;
Best Luck!
dear tushar,
thank you for your time.
I have already tried this by setting the defaultfaces to empty but this will not help to solve the problem.
Its showing higher velocities at the patch surface, which result in too high courant number.
Do you know how i am getting these internal faces, without defining any where in the blockMesh dictionary.
Old   November 13, 2014, 05:34
T. Chourushi
dear tushar,
Dear Arjun,
The error is in the blockMesh, due to node (9, 19) which is connected to a face. If you remove this node and use only 3 blocks it will work, as it will follows the block rule.
If your case demands such mesh only. Then, you can try "merge" option of OpenFOAM. Although, I never tried it but I think that will help you resolve.
Please, do share to FOAM community if you happen to get correct solutions.
Best Luck!
Old   November 13, 2014, 06:36
Arjun
Dear Arjun,
Best Luck!
dear tushar,
I need to define a patch on face (4 14 15 5).
If i try with 3 blocks it will lead to error "face 0 in patch 0 does not have neighbour cell face: 4(4 14 15 5).
I am not familiar with merge. which all faces do you suggest to merge.
Thank you
Old   November 13, 2014, 07:20
T. Chourushi
dear tushar,
Thank you
Dear Arjun,
You can easily construct 3 block for the case which you have referred in the figure. Follow carefully the blockMesh strategy of OpenFOAM, refer link below for the same:
http://www.openfoam.org/docs/user/blockMesh.php
For merge patch I am not an expert. You can explore it.
Best Luck!
Old   November 13, 2014, 14:03
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
An alternative method is to generate the 3-block mesh which works, then use topoSet to select the faces that correspond to face 4 14 15 5 and use createPatch to generate the boundary patch.
I've found this approach is more consistent and allows you to make all kinds of boundary patches that only partially cover the domain boundaries, and requires less debugging of the blockMesh dict file which can become a real headache.
mturcios777 is offline   Reply With Quote
Old   November 14, 2014, 06:48
Arjun
Thank you for your suggestion Marco. I think it will take some time for me to familiarize with topoSet utility. Will post the updates and looking forward to your help in future.
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
parallel run OpenFoam Srinath Reddy OpenFOAM Running, Solving & CFD 13 February 27, 2019 09:15
[blockMesh] Difficulty creating internal faces salomama OpenFOAM Meshing & Mesh Conversion 1 August 19, 2018 15:45
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
