[Gmsh] gmshToFOAM: Found undefined faces in mesh
Like Tree2Likes
  • 1 Post By sisi
  • 1 Post By alexeym
Old   November 30, 2014, 17:32
Default gmshToFOAM: Found undefined faces in mesh
sisi is on a distinguished road
I am having some trouble with gmshToFOAM. So far the OpenFOAM "cavity" tutorial with the blockMesh utility works fine. Now I would like to solve the "cavity" problem using an unstructured mesh created by Gmesh:
lc = 0.01;
tc = 0.001; // top corners
bc = 0.0025; // bottom corners
Point(1) = { 0, 0, 0, lc };
Point(2) = { 0.05, 0, 0, lc };
Point(3) = { 0.1, 0, 0, lc };
Point(4) = { 0.1, 0.05, 0, lc };
Point(5) = { 0.1, 0.1, 0, tc };
Point(6) = { 0.05, 0.1, 0, lc };
Point(7) = { 0, 0.1, 0, tc };
Point(8) = { 0, 0.05, 0, lc };
Line(1) = {1,2};
Line(2) = {2,3};
Line(3) = {3,4};
Line(4) = {4,5};
Line(5) = {5,6};
Line(6) = {6,7};
Line(7) = {7,8};
Line(8) = {8,1};
Line Loop (9) = {1:8};
Plane Surface(1) = {9};
Extrude {0, 0, 0.1} {
Surface{1};
Layers{1};
Recombine;
Physical Surface("front") = {46,50};
Physical Surface("back") = {34,30};
Physical Surface("bottom") = {22,26};
Physical Surface("left") = {1};
Physical Surface("top") = {42,38};
Physical Surface("right") = {51};
Physical Volume("internal") = {1};
Mesh 3;
Save "cavity.msh";
I am getting the following terminal outputs:
$ gmshToFoam cavity.msh
Create time
Starting to read mesh format at line 2
Read format version 2.2  ascii 0
Starting to read physical names at line 5
Physical names:7
    Surface 1    front
    Surface 2    back
    Surface 3    bottom
    Surface 4    left
    Surface 5    top
    Surface 6    right
    Volume 7    internal
Starting to read points at line 15
Vertices to be read:652
Vertices read:652
Starting to read cells at line 670
Cells to be read:1806
Mapping region 4 to Foam patch 0
Mapping region 6 to Foam patch 1
Mapping region 3 to Foam patch 2
Mapping region 2 to Foam patch 3
Mapping region 5 to Foam patch 4
Mapping region 1 to Foam patch 5
Mapping region 7 to Foam cellZone 0
Cells:
    total:578
    hex  :0
    prism:578
    pyr  :0
    tet  :0
CellZones:
Zone    Size
    0    578
Skipping tag  at line 2479
Patch 0 gets name left
Patch 1 gets name right
Patch 2 gets name bottom
Patch 3 gets name back
Patch 4 gets name top
Patch 5 gets name front
--> FOAM Warning :
    From function polyMesh::polyMesh(... construct from shapes...)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 627
    Found 1228 undefined faces in mesh; adding to default patch.
Finding faces of patch 0
Finding faces of patch 1
Finding faces of patch 2
Finding faces of patch 3
Finding faces of patch 4
Finding faces of patch 5
FaceZones:
Zone    Size
Writing zone 0 to cellZone internal and cellSet
End
and
$ icoFoam
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for left
file: ~/.../run/tutorials/incompressible/icoFoam/cavity/0/p.boundaryField from line 25 to line 35.
    From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&)
    in file ~/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 209.
FOAM exiting
Any ideas how to solve this problem?
charlliemarshalll likes this.
sisi is offline   Reply With Quote
Old   December 1, 2014, 02:10
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
This
--> FOAM Warning :
can be ignored. As gmshToFoam first adds all boundary faces to defaultFaces patch and then move faces to patches defined in MSH file. IIRC I've already posted explanation on the forum, or you can take a look at sources of gmshToFoam.
Second error: add left patch description to p file in 0 folder. Here's the names of the patches in the cavity tutorial:
boundaryField
    movingWall
        type            zeroGradient;
    fixedWalls
        type            zeroGradient;
    frontAndBack
        type            empty;
either you change names of physical groups in your mesh, or you change names of the patches in 0 folder (p and U) files according to your mesh.
Ramzy1990 likes this.
alexeym is offline   Reply With Quote
Old   December 1, 2014, 07:00
Thanks for your quick reply! I made the following changes to the cavity.geo file but icoFOAM still not working
Physical Surface("fixedWalls") = {46, 50, 22, 26, 30, 34};
Physical Surface("frontAndBack") = {51, 1};
Physical Surface("movingWall") = {42, 38};
Running gmshToFoam
Create time
Physical names:4
    Surface 1    fixedWalls
    Surface 2    frontAndBack
    Surface 3    movingWall
    Volume 4    internal
Starting to read points at line 12
Vertices to be read:826
Vertices read:826
Starting to read cells at line 841
Cells to be read:2288
Mapping region 2 to Foam patch 0
Mapping region 1 to Foam patch 1
Mapping region 4 to Foam cellZone 0
Cells:
    total:732
    hex  :0
    prism:732
    pyr  :0
    tet  :0
CellZones:
Zone    Size
    0    732
Skipping tag  at line 3132
Patch 0 gets name frontAndBack
Patch 1 gets name fixedWalls
Patch 2 gets name movingWall
--> FOAM Warning :
    Found 1556 undefined faces in mesh; adding to default patch.
FaceZones:
Zone    Size
End
and finally icoFoam leads to
Create time
Reading field p
    patch type 'patch' not constraint type 'empty'
    for patch frontAndBack of field p in file "...cavity/gmsh/0/p"
file: ~/.../cavity/gmsh/0/p.boundaryField.frontAndBack from line 35 to line 35.
    From function emptyFvPatchField<Type>::emptyFvPatchField
    const fvPatch& p,
    const Field<Type>& field,
    const dictionary& dict
    in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 100.
FOAM exiting
What does it mean?
File Type: txt cavity.txt (828 Bytes, 6 views)
Old   December 1, 2014, 07:16
Alexey Matveichev
Gmsh doesn't store boundary type information in mesh file, all boundaries has type 'patch' (in OpenFOAM's terminology) after conversion.
Cavity tutorial is 2D, frontAndBack boundary should have 'empty' type, fixedWalls and movingWall should have 'wall' type (though for cavity tutorial this is not so important). You should edit constant/polyMesh/boundary file and set correct types. Either by hand, or with changeDictionary utility.
Old   December 1, 2014, 09:07
I tried to follow your instructions. The attached file is the modified boundary file. I still getting an error message:
Create time
wrong token type - expected word, found on line 23 the label 1
file: .frontAndBack.physicalType at line 23.
    From function operator>>(Istream&, word&)
    in file primitives/strings/word/wordIO.C at line 74.
FOAM exiting
Old   December 1, 2014, 09:27
Alexey Matveichev
Well,
As it said, it expects word (empty), while you've put list there (1(empty)).
If you take a look at patchIdentifier.H:122, you'll see that physicalType of the patch is word.
I.e. this
    frontAndBack
        type            empty;
        physicalType    1(empty);
        nFaces          1464;
        startFace       1052;
in fact should be
    frontAndBack
        type            empty;
        physicalType    empty;
        nFaces          1464;
        startFace       1052;
or even
    frontAndBack
        type            empty;
        nFaces          1464;
        startFace       1052;
as physical type of the patch is optional thing.
The same with other patches.
Old   December 1, 2014, 11:08
Sorry! So the boundary file should look like this?
frontAndBack
        type            empty;
        physicalType    empty;
        nFaces          1464;
        startFace       1052;
    fixedWalls
        type            wall;
        physicalType    empty;
        nFaces          60;
        startFace       2516;
    movingWall
        type            wall;
        physicalType    empty;
        nFaces          32;
        startFace       2576;
Why am I still getting an error message?
Create time
cannot find file
file: ~/..../tutorials/incompressible/icoFoam/cavity/gmsh/constant/polyMesh/system/controlDict at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Old   December 1, 2014, 11:11
Alexey Matveichev
It's worth reading the error (and trying to understand it) before posting message here. You're trying to run a case in constant/polyMesh folder instead of case folder.
Old   December 1, 2014, 11:54
Thanks for helping me and being so patient Works now!
Originally Posted by alexeym View Post
Well,
Link not working. Please fix...
Old   December 1, 2014, 11:59
Alexey Matveichev
Hm, that's right, posted a link to a local copy of documentation instead of sourceforge. Fixed.
Old   December 2, 2014, 11:39
Thank you again for all your assistance!
Old   March 14, 2016, 10:50
ok
Maimouna is on a distinguished road
Hi Alexey,
I need your help please. I'm doing fsi case about beam in cross flow attached to the square cylinder. I generated mesh using Gmsh.
cl1 = 0.5;
cl2 = 0.2;
Point(1) = {0, 0, 0, cl1};
Point(2) = {20, 0, 0, cl1};
Point(3) = {0, 11, 0, cl1};
Point(4) = {20, 11, 0, cl1};
Point(11) = {0, 0, 11, cl1};
Point(12) = {20, 0, 11, cl1};
Point(13) = {0, 11, 11, cl1};
Point(14) = {20, 11, 11, cl1};
Line(1) = {1, 11};
Line(2) = {11, 12};
Line(3) = {12, 2};
Line(4) = {2, 1};
Line(5) = {13, 14};
Line(6) = {14, 4};
Line(7) = {4, 3};
Line(8) = {3, 13};
Line(9) = {11, 13};
Line(10) = {12, 14};
Line(11) = {2, 4};
Line(12) = {1, 3};
Line Loop(13) = {1, 2, 3, 4};
Plane Surface(14) = {13};
Line Loop(15) = {8, 5, 6, 7};
Plane Surface(16) = {15};
Line Loop(17) = {1, 9, -8, -12};
Plane Surface(18) = {17};
Line Loop(19) = {3, 11, -6, -10};
Plane Surface(20) = {19};
Line Loop(21) = {2, 10, -5, -9};
Plane Surface(22) = {21};
Line Loop(23) = {4, 12, -7, -11};
Plane Surface(24) = {23};
Point(101) = {5, 5, 4, cl2};
Point(102) = {6, 5, 4, cl2};
//thickness of plate is 0.1
Point(103) = {6, 5+0.45, 4, cl2};
Point(104) = {6, 5+0.55, 4, cl2};
Point(105) = {6, 6, 4, cl2};
Point(106) = {5, 6, 4, cl2};
For i In {1:5}
Line(100+i) = {100+i, 100+i+1};
EndFor
Line(106) = {106, 101};
Line Loop(111) = {101, 102, 103, 104, 105, 106};
Plane Surface(111) = {111};
Point(113) = {6+4, 5+0.45, 4, cl2};
Point(114) = {6+4, 5+0.55, 4, cl2};
Line(113) = {103, 113};
Line(114) = {104, 114};
Line(115) = {113, 114};
Line Loop(116) = {103, 114, -115, -113};
Plane Surface(117) = {116};
vo1[]={Extrude {0, 0, 3} {Surface{111, 117};} };
Surface Loop(172) = {18, 14, 22, 20, 24, 16};
Surface Loop(173) = {170, 117, 162, 166, 171, 148, 111, 128, 132, 149, 140, 144};
Volume(174) = {172, 173};
Physical Surface("inlet") = {18};
Physical Surface("outlet") = {20};
Physical Surface("top") = {16};
Physical Surface("bottom") = {14};
Physical Surface("front") = {22};
Physical Surface("back") = {24};
Physical Surface("cylinder") = {128, 148, 111, 149, 144, 132};
Physical Surface("plate") = {166, 140, 117, 162, 170, 171};
Coherence;
I saved .geo and .msh files in my case and then gmshToFoam fluid.msh, I got the following
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 3.1 |
| \\ / A nd | Web: http://www.extend-project.de |
| \\/ M anipulation | |
Build : 3.1-f61aab88e799
Exec : gmshToFoam fluid.msh
Date : Mar 14 2016
Time : 15:33:51
Host : owner-HP-Pavilion-Sleekbook-15-PC
PID : 5319
CtrlDict : /home/owner/foam/foam-extend-3.1/etc/controlDict
Case : /home/owner/foam/owner-3.1/FluidStructureInteraction/run/fsiFoam/beamInCrossFlowAttachedCylinder/fluid
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Found $MeshFormat tag; assuming version 2 file format.
Physical names:8
Surface 1 inlet
Surface 2 outlet
Surface 3 top
Surface 4 bottom
Surface 5 front
Surface 6 back
Surface 7 cylinder
Surface 8 plate
Starting to read points at line 16
Vertices to be read:7216
Vertices read:7216
Starting to read cells at line 7235
Cells to be read:14424
Mapping region 3 to Foam patch 1
Mapping region 1 to Foam patch 2
Mapping region 6 to Foam patch 5
Mapping region 7 to Foam patch 6
Mapping region 8 to Foam patch 7
Cells:
total:0
hex :0
prism:0
pyr :0
tet :0
--> FOAM FATAL ERROR:
No cells read from file "fluid.msh"
Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)?
Perhaps you have not exported the 3D elements?
From function readCells(..)
in file gmshToFoam.C at line 690.
FOAM exiting
My second trying was saving that two files in constant/polyMesh folder as you recommended sisi in post #8, but I got same as sisi error
Create time --> FOAM FATAL IO ERROR: cannot find file file: ~/..../tutorials/incompressible/icoFoam/cavity/gmsh/constant/polyMesh/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting
How could solve that? What's the problem.
My boundary file is
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
8
top
type patch;
nFaces 1600;
startFace 314900;
bottom
type patch;
nFaces 1600;
startFace 316500;
outlet
type patch;
nFaces 1500;
startFace 318100;
inlet
type patch;
nFaces 1200;
startFace 319600;
cylinder
type wall;
nFaces 1200;
startFace 320800;
interface
type wall;
nFaces 600;
startFace 322000;
front
type wall;
nFaces 4500;
startFace 322600;
back
type wall;
nFaces 4500;
startFace 327100;
Many thanks in advanced.
Maimouna
Maimouna is offline   Reply With Quote
Old   March 14, 2016, 11:24
Alexey Matveichev
You do not have Physical Volume definition in your mesh.
For example if you take this simple GEO:
Point(1) = {0, 0, 0};
Point(2) = {1, 0, 0};
Point(3) = {1, 1, 0};
Point(4) = {0, 1, 0};
Line(1) = {1, 2};
Line(2) = {2, 3};
Line(3) = {3, 4};
Line(4) = {4, 1};
Line Loop(5) = {4, 1, 2, 3};
Plane Surface(6) = {5};
Extrude {0, 0, 1} {
  Surface{6};
  Layers{10};
  Recombine;
Transfinite Line {1, 2, 3, 4} = 11;
Transfinite Surface "*";
Recombine Surface "*";
Physical Surface("walls") = {28, 15, 27, 23, 6, 19};
Physical Volume("cube") = {1};  // *
Mesh 3;
Save "test.msh";
and try running it though Gmsh; without Physical Volume definition (comment out line marked with *), you get the following element list in msh-file:
$Elements
600
1 3 2 1 6 4 36 117 35
2 3 2 1 6 35 117 118 34
600 3 2 1 28 602 62 7 63
$EndElements
i.e. mesh does not contain any 3D elements; with Physical Volume definition:
$Elements
1600
601 5 2 2 1 4 36 117 35 81 198 603 513
1600 5 2 2 1 1331 359 107 368 602 62 7 63
$EndElements
Old   March 14, 2016, 12:18
ok
Hi Alexey,
I just added the following line for Physical surface to my previous geo file
Physical Volume(200) = {vo1[]};
and I got screen with full of warnings (attached). Why and how to solve?
With lots of thanks.
Maimouna
Old   March 14, 2016, 14:25
Alexey Matveichev
And why not
Physical Volume("mesh") = {174};
(you can use 200 instead of "mesh" if you like)?
Old   March 14, 2016, 16:08
ok
Ok dear. I got
Date : Mar 14 2016
Time : 21:03:41
PID : 2486
nProcs : 1
Create time
Physical names:9
Surface 1 inlet
Surface 2 outlet
Surface 3 top
Surface 4 bottom
Surface 5 front
Surface 6 back
Surface 7 cylinder
Surface 8 interface
Volume 9 mesh
Starting to read points at line 17
Vertices to be read:23732
Vertices read:23732
Starting to read cells at line 23752
Cells to be read:142726
Mapping region 9 to Foam cellZone 0
Cells:
total:128340
hex :0
prism:0
pyr :0
tet :128340
CellZones:
Zone Size
0 128340
Skipping tag at line 166481
Patch 0 gets name bottom
Patch 1 gets name top
Patch 2 gets name inlet
Patch 3 gets name outlet
Patch 4 gets name front
Patch 5 gets name back
Patch 6 gets name cylinder
Patch 7 gets name interface
--> FOAM Warning :
From function polyMesh:olyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 626
Found 14386 undefined faces in mesh; adding to default patch.
Finding faces of patch 6
Finding faces of patch 7
FaceZones:
Zone Size
From function void polyMesh::initMesh()
in file meshes/polyMesh/polyMeshInitMesh.C at line 81
Truncating neighbour list at 249487 for backward compatibility
Writing zone 0 to cellZone mesh and cellSet
End
Again, what is the problem please?
Old   March 15, 2016, 03:01
Alexey Matveichev
Well, output depends on Gmsh version, mesh generation settings, and the state of gmshToFoam in foam-extend (last time I dealt with it, I had to implement removal of empty patches after conversion).
With 2.10.0, default mesh generation settings, and gmshToFoam from OpenFOAM 2.4.0 conversion went OK.
Old   March 15, 2016, 05:16
ok
Hi Alexey,
I'm using Gmsh 2.8.3 for foam-extend-3.1. What should do now? What are the next steps? Shall remove defaultFaces from the boundary file?
Regards
Maimouna
Old   March 15, 2016, 07:15
Alexey Matveichev
Dear Maimouna,
Unfortunately I can not decide what YOU should do with YOUR simulation. You have foam-extend installed, check sources of gmshToFoam, learn the reason for
Truncating neighbor list at 249487 for backward compatibility
Are you sure FSI solvers capable of running on on tetrahedral meshes? Also your geometry is trivially meshed with hexahedra.
Old   March 15, 2016, 08:39
ok
Hi Alexey,
honestly, I'm not very sure if FSI solver would capable running on tetrahedral meshes, but suppose should be running for all mesh types regarding
HTML Code:
https://www.ricam.oeaw.ac.at/files/reports/12/rep12-11.pdf
So, in my case, what do you advice me to do? Shall I move to another solver? Guide me please.
Best regards
Maimouna
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
