[Other] Issue Exporting Pointwise Mesh to OF2.3.x |
October 6, 2015, 08:00 |
Jack
Rep Power: 11 |
My problem is as follows. I downloaded a simple example case from Travis Carrigan at https://github.com/traviscarrigan/OpenFOAM-NACA2412
As the case is set up from unzipping everything works perfectly fine. However, If I open the pointwise project that is included in the polyMesh directory and export the mesh using Export -> CAE and use these files in my simulation then OF complains with a floating point exception! You can try for yourself as I attach the link to the case above. In the polyMesh directory simply copy the files I atach which got when exporting the project from pointwise from the 'Travis' directory to polyMesh to get the case that gives the error. The case as provided by Travis should work as is. You can examine the files in 'Mine' and the ones in 'Travis' and see they are different but they were supposedly generated using the same pointwise export method! https://www.justbeamit.com/9t57q If anyone can help on this issue it would be much appreciated! |
October 6, 2015, 09:33 |
Jack
Rep Power: 11 |
Solved the problem with the help of Travis - you need to run renumberMesh -overwrite in the case directory. Hope this helps with people encountering a similar issue.
export, openfoam, pointwise, pointwise cgns msh |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] Snappy Hex Mesh - issue with smoothness of the model edges | olek.warc | OpenFOAM Meshing & Mesh Conversion | 1 | August 31, 2018 11:31 |
Error when exporting 3D mesh from pointwise to cfx | razally | CFX | 4 | November 20, 2015 19:37 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
