[Other] cyclicAMI for non-matching interfaces
Old   October 9, 2015, 04:48
Default cyclicAMI for non-matching interfaces
Hannes Grimm-Strele
HannesGS is on a distinguished road
Dear all,
I have a very simple test case here: just two structured blocks with different number of points as shown on the attached picture. I used the cyclicAMI type to define the interface.
P1
type cyclicAMI;
nFaces 64;
startFace 4528;
matchTolerance 0.001;
transform noOrdering;
neighbourPatch P2;
(analogously for the other side P2). Now, checkMesh tells me
*Number of regions: 2
The mesh has multiple regions which are not connected by any face.
<<Writing region information to "0/cellToRegion"
<<Writing region 0 with 512 cells to cellSet region0
<<Writing region 1 with 1152 cells to cellSet region1
Is this a warning I have to worry about? Is my general approach towards non-matching interfaces valid at all?
Thank you for your help!
HannesGS is offline   Reply With Quote
Old   October 12, 2015, 05:59
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I guess this should work. You may want to check that the regions are on either side of the cyclicAMI interface in ParaView (use the cellToRegion variable). Due to the non-conformal interface there is no direct connection between the regions, which would indeed trigger this warning.
Regards,
Tom
tomf is offline   Reply With Quote
Old   October 13, 2015, 07:49
Hannes Grimm-Strele
A simple test simulation runs nicely, I just was a bit worried by the warning. Thanks for your answer and the explanation!
Using createPatch and cyclicAMI in FOAM Extend to create periodicbox manuc OpenFOAM Running, Solving & CFD 1 April 12, 2022 11:36
Flux not conserved in cyclicAMI interfaces if areas are different jherb OpenFOAM Programming & Development 1 January 23, 2019 10:22
cyclicAMI - kOmegaSST - divergence issue cyln OpenFOAM Running, Solving & CFD 1 October 5, 2018 10:06
cyclic / cyclicAMI boundary conditon - ICEM Mesh cyln OpenFOAM Running, Solving & CFD 0 November 7, 2017 15:26
cyclicAMI for non matching geometry? tms OpenFOAM Running, Solving & CFD 7 September 3, 2012 06:47
