October 15, 2015, 00:40 |
About the arc in blockMesh
Zhifang Hu
Rep Power: 10 |
It may be a weird question, but that's what i am facing now.
I am using OpenFoam 2.4.0 to run a fluid simulation over a pipe in 2D and i build the geometry using blockMesh. I build a circular pipe by define a square first, then use arc to make it circular. The weird thing is that if i left the pipe to be square and run the simulation, everything goes fine. However, if i use the arc and make the pipe be circular, i faced the problem that dT is constant shrinking during the simulation (about half the size of previous iteration), which leads to a really small dT value, then the simulation breaks down. Anyone have any suggestions for me. Thanks |
October 22, 2015, 03:40 |
Nima Samkhaniani
Rep Power: 24 |
before run the simulation, use "checkMesh" to investigate mesh quality
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
[blockMesh] Openfoam: Meshing, where do my defaultFaces come from | syntex | OpenFOAM Meshing & Mesh Conversion | 19 | December 10, 2018 07:21 |
settlingFoam unstable? | bendel_boy | OpenFOAM Running, Solving & CFD | 38 | July 8, 2016 05:07 |
[blockMesh] Another cylinder question | bendel_boy | OpenFOAM Meshing & Mesh Conversion | 5 | January 6, 2015 05:09 |
[Other] mergeMatchPairs with arcs | vainilreb | OpenFOAM Meshing & Mesh Conversion | 1 | August 5, 2013 08:11 |
[blockMesh] apparently the mesh doesn't want to be created in one direction | Maxime Thomas | OpenFOAM Meshing & Mesh Conversion | 1 | August 18, 2012 06:05 |
