November 20, 2015, 09:20 |
blockMesh - 2D
Rep Power: 11 |
Hey guys,
I'm working with OF for quite a year by now and I thought I knew the basics about blockMesh but I got a little bit confused about 2D meshes. OF always operates in 3 dimensions, so all geometries are generated in 3 dimensions. When I want to setup a 2D case, I just define the empty boundary condition on boundaries normal to the 3rd dimensions. Well, so far so good. How many cells do I have to have at this 3rd dimension? I looked up some tutorial cases and all of them have just 1 cell. That's what I've thought to be right but I couldn't find anything saying this to be just 1 cell! Am I right by assuming that 2D cases MUST have ONLY 1 cell in the 3rd dimension or is it also possible to have more cells? Thanks |
November 20, 2015, 12:57 |
Anton Kidess
Rep Power: 30 |
More than one cell in the third dimension makes no sense. Why refine in a direction without gradients?
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
November 21, 2015, 03:58 |
#3 | |
Rep Power: 11 |
For my case, I would therefore need 5 cells in the 3rd dimensions. That's why I'm asking So, is it possible to simulate this in 2D? Thanks |
November 21, 2015, 05:20 |
Anton Kidess
Rep Power: 30 |
I don't understand your drawing. Your geometry is confined to the XY-plane? Then only use one cell in Z direction and you're done. If you're domain is axisymmetric, use a wedge.
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 7 | August 25, 2020 19:15 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
[blockMesh] External flow around cube with blockMesh | Woody8 | OpenFOAM Meshing & Mesh Conversion | 0 | March 31, 2015 14:54 |
[blockMesh] set of xyz data in blockMesh | psk | OpenFOAM Meshing & Mesh Conversion | 12 | August 27, 2013 08:37 |
Blockmesh cavity error message | tonitoney | OpenFOAM Installation | 2 | March 17, 2008 11:59 |
