[blockMesh] blockMesh - 2D
Old   November 20, 2015, 09:20
Default blockMesh - 2D
Harak is on a distinguished road
Hey guys,
I'm working with OF for quite a year by now and I thought I knew the basics about blockMesh but I got a little bit confused about 2D meshes.
OF always operates in 3 dimensions, so all geometries are generated in 3 dimensions. When I want to setup a 2D case, I just define the empty boundary condition on boundaries normal to the 3rd dimensions. Well, so far so good.
How many cells do I have to have at this 3rd dimension? I looked up some tutorial cases and all of them have just 1 cell. That's what I've thought to be right but I couldn't find anything saying this to be just 1 cell! Am I right by assuming that 2D cases MUST have ONLY 1 cell in the 3rd dimension or is it also possible to have more cells?
Thanks
Harak is offline   Reply With Quote
Old   November 20, 2015, 12:57
akidess's Avatar
Anton Kidess
More than one cell in the third dimension makes no sense. Why refine in a direction without gradients?
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   November 21, 2015, 03:58
Because I want to simulate a beam with a circular cross section in a flow channel and therefore I need more than 1 plane in the 3rd dimension. As you know, it's necessary to have 5 planes to define a circle with blockMesh (see attached image).
For my case, I would therefore need 5 cells in the 3rd dimensions. That's why I'm asking
So, is it possible to simulate this in 2D?
Thanks
Old   November 21, 2015, 05:20
akidess's Avatar
Anton Kidess
I don't understand your drawing. Your geometry is confined to the XY-plane? Then only use one cell in Z direction and you're done. If you're domain is axisymmetric, use a wedge.
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] External flow around cube with blockMesh Woody8 OpenFOAM Meshing & Mesh Conversion 0 March 31, 2015 14:54
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
