[Commercial meshers] starCCM+ to OpenFOAM mesh |
stefano zinna
Rep Power: 17 ![]() |
Hi All,
I am interested in the transferring between starCCM+ and OpenFOAM meshes. I did successfully for simple geometry but I got issues for complex ones. I read in an old Thread that: "Also, the polymesh that Star creates is not always great quality. The solver can handle it because it just turns off those poor quality cells (just doesn't solve them) if they start to be a problem." I exported a ccm mesh that it was running in starCCM+. When I used ccm26toFoam to import in OpenFOAM I get very bad cell quality and wrong oriented faces (by checkMesh). I tried also to import the mesh from starCCM+ to Fluent and the mesh check (in fluent) shows similar issue (for orthogonal quality and aspect ratio). Hence I was wondering if what I read in the old thread is true and If there is away to transfer a good quality mesh from starCCM+ to OpenFOAM. thanks! regards, Stefano |
pulkit
Rep Power: 12 ![]() |
Hi stefano,
I have faced similar problems in converting ccm+ mesh to OpenFOAM formats. There are always some cells of poor quality that lead to solver crashing in very initial iterations itself. The conversion works sometimes on relatively simplified geometries but even then this process is not very reliable. After a few attempts on different geometries, I stopped making further efforts in this direction and now use cfMesh for most of my meshing tasks. Thanks, Pulkit |
stefano zinna
hi Pulkit,
I tried polyhedral cells and now i am trying tetrahedral cells. With polyhedral worked on simple geometry as you said. The problem is also that from the quality report i couldn't see the issue in starccm+ while it was evident in the quality check in openfoam. For this reason i did not know if to blame starccm+ or the converter (ccm26tofoam). I will let you know if i find a way. thanks. Stefano |
pulkit
Hi Stefano,
This apparent difference in quality check might be due to the fact that ccm+ solver is more capable of handling cells of poor quality whereas the oepnfoam solver is a bit stringent on the quality check as it can operate on good quality cells only. Also, the converter ccm26tofoam poses some limitations with regards to mesh conversion for complex geometries. Nevertheless, I appreciate your effort to continue in this direction. Will be great to hear back from you if you find a way. Thanks, Pulkit |
[Commercial meshers] About the Commercial and Closed Source Meshers discussed here | wyldckat | OpenFOAM Meshing & Mesh Conversion | 3 | July 22, 2020 22:09 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
[Commercial meshers] OpenFoam Mesh to Fluent Mesh in parallel case | DominicTNC | OpenFOAM Meshing & Mesh Conversion | 3 | November 22, 2017 09:19 |
OpenFOAM Foundation releases OpenFOAM 2.2.2 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | October 14, 2013 07:18 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
