[mesh manipulation] SplitMeshRegions creating more regions than specified |
Gregor Alan
Rep Power: 10 ![]() |
Dear all,
For my first conjugate heat transfer problem I have made two Fluent meshes and imported these succesfully and merged these (ran checkMesh and it says ok apart from some non-orthogonal faces). Then I have used topoSet to define 2 cellZonesSets the 'pin' part and the 'topAir' part, which are an aluminium cylindrical pin and the fluid flowing around it. The problem is that when I run 'splitMeshRegions -cellZones -overwrite' it creates 5 regions instead of 2. Does anybody know why it is doing this? Regards, Gregor SOLVED: I ran splitMeshRegions -cellZonesOnly, that gave 2 regions of equal amount of cells as from the topoSet function Last edited by GregorAlan; February 3, 2016 at 07:36. |
splitmeshregions |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
Issues with splitMeshRegions! | vabishek | OpenFOAM Pre-Processing | 6 | October 25, 2018 13:16 |
Error by creating interfaces for Multiple Regions – Heat Transfer | Sakuyalex | STAR-CCM+ | 3 | March 22, 2018 04:16 |
splitMeshRegions doesn't find my regions. | GPesch | OpenFOAM Pre-Processing | 2 | November 14, 2013 05:20 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
