[blockMesh] blockMesh breaks down when handling with huge grid numbers
Like Tree3Likes
  • 1 Post By akidess
  • 1 Post By jherb
  • 1 Post By akidess
Old   June 19, 2016, 23:08
Unhappy blockMesh breaks down when handling with huge grid numbers
Democritus's Avatar
Xiaoqiu HE
Democritus is on a distinguished road
Hello Foamers~!
Here I met a serious problem: when i want to generate a mesh with grid number of 1e8, blockMesh just breaks down. Here is my mesh dict:
vertices
    (0    0     0)        //0
    ($Lx  0     0)        //1
    ($Lx  $Ly   0)        //2
    (0    $Ly   0)        //3
    (0    0     $Lz)      //4
    ($Lx  0     $Lz)      //5
    ($Lx  $Ly   $Lz)      //6
    (0    $Ly   $Lz)      //7
blocks
  hex ( 0 1 2 3 4 5 6 7 ) (10000 10000 1) simpleGrading (10 10 1)
Is there a way to deal with that problem? Thanks!
Democritus is offline   Reply With Quote
Old   June 20, 2016, 09:15
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
"Breaks down" is a very unspecific description. I'd blame your memory.
Democritus likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   June 20, 2016, 15:26
Joachim Herb
jherb is on a distinguished road
Just a complete shot in the dark: Did you compile OpenFOAM with 32 or 64 bit label size?
see e. g. http://openfoamwiki.net/index.php/Label and https://github.com/OpenFOAM/OpenFOAM...etc/bashrc#L81
jherb is offline   Reply With Quote
Old   June 20, 2016, 22:32
Democritus's Avatar
Xiaoqiu HE
Thank you very much for your attention on my problem
I now describe my situation in more details:
As you predicted, the memory ran out quickly and the hard disk was busy. Then the program do not response any more and I have to shut it down forcely. I think blockMesh generates the mesh information all in memory and do not write to disk until finished computing. So the memory become the bottleneck of my system.
Here is my idea about how to solve it:
1. generate the coarse mesh
2. use multi-thread tool in order to decompose the mesh to different sub mesh
3. refine every sub meshes in parallel
Would you please give me some advices about how to make it?
Thanks very much!
Old   June 20, 2016, 22:38
Democritus's Avatar
Xiaoqiu HE
I work with ubuntu 16.04 and I installed OpenFOAM by the apt command. So I think my label set is the default value
Is there a way to install OpenFOAM with label value equaling to 64 by apt command?
Thank you very much!
Old   June 21, 2016, 01:58
akidess's Avatar
Anton Kidess
Yes, you can go that way. Some ideas here:
http://www.cfd-online.com/Forums/ope...eneration.html
Thanks very much!
Old   June 21, 2016, 23:32
Red face
Democritus's Avatar
Xiaoqiu HE
Dear akidess,
I have tried the 3-step-Meshing:
1. blockMesh a coarse mesh and topoSet a cellSet
2. decomposePar for making it ready for parallel processing
3. mpirun -np 8 refineMesh -overwrite -parallel
This works fine until the memory bottleneck was met
Now it comes to me a idea that if i can refineMesh one subMesh by one subMesh. I mean, if it is possible that i refine one subMesh once but still parallelly. I guess if the meshing domain could be limited to one subMesh and exploited all cpu cores' power, then the memory needed is affordable for me and the performance is ok.
Old   June 23, 2016, 02:39
akidess's Avatar
Anton Kidess
If you run on a single node, of course running in parallel will not gain you anything in terms of memory. If you don't have more than a single node, you are out of luck I think. Yeah, you can mesh subdomains separately and then stich, but you'll probably still dump once you stitch and get the large mesh, or finally when you attempt to solve.
Old   July 4, 2016, 21:09
Democritus's Avatar
Xiaoqiu HE
Thank you~! I am trying to use other way like mesh grading to solve the problem.
Grid with huge dimensions Sadegh.A Mesh Generation & Pre-Processing 0 December 30, 2018 15:23
multiphase flow in huge dimensions Sadegh.A Main CFD Forum 0 December 27, 2018 09:37
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 14:17
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
Non-uniform grid calculation Aspens Main CFD Forum 1 February 23, 2000 14:15
