[blockMesh] blockMesh breaks down when handling with huge grid numbers |
June 19, 2016, 23:08 |
Xiaoqiu HE
Rep Power: 10 |
Hello Foamers~!
Here I met a serious problem: when i want to generate a mesh with grid number of 1e8, blockMesh just breaks down. Here is my mesh dict: Code:
vertices ( (0 0 0) //0 ($Lx 0 0) //1 ($Lx $Ly 0) //2 (0 $Ly 0) //3 (0 0 $Lz) //4 ($Lx 0 $Lz) //5 ($Lx $Ly $Lz) //6 (0 $Ly $Lz) //7 ); blocks ( hex ( 0 1 2 3 4 5 6 7 ) (10000 10000 1) simpleGrading (10 10 1) ); |
June 20, 2016, 09:15 |
Anton Kidess
Rep Power: 30 |
"Breaks down" is a very unspecific description. I'd blame your memory.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
June 20, 2016, 15:26 |
Joachim Herb
Rep Power: 21 |
Just a complete shot in the dark: Did you compile OpenFOAM with 32 or 64 bit label size?
see e. g. http://openfoamwiki.net/index.php/Label and https://github.com/OpenFOAM/OpenFOAM...etc/bashrc#L81 |
June 20, 2016, 22:32 |
#4 | |
Xiaoqiu HE
Rep Power: 10 |
I now describe my situation in more details: As you predicted, the memory ran out quickly and the hard disk was busy. Then the program do not response any more and I have to shut it down forcely. I think blockMesh generates the mesh information all in memory and do not write to disk until finished computing. So the memory become the bottleneck of my system. Here is my idea about how to solve it: 1. generate the coarse mesh 2. use multi-thread tool in order to decompose the mesh to different sub mesh 3. refine every sub meshes in parallel Would you please give me some advices about how to make it? Thanks very much! Last edited by Democritus; June 21, 2016 at 01:37. |
June 20, 2016, 22:38 |
#5 | |
Xiaoqiu HE
Rep Power: 10 |
I work with ubuntu 16.04 and I installed OpenFOAM by the apt command. So I think my label set is the default value Is there a way to install OpenFOAM with label value equaling to 64 by apt command? Thank you very much! |
June 21, 2016, 01:58 |
#6 | |
Anton Kidess
Rep Power: 30 |
Yes, you can go that way. Some ideas here:
http://www.cfd-online.com/Forums/ope...eneration.html Quote:
June 21, 2016, 23:32 |
#7 | |
Xiaoqiu HE
Rep Power: 10 |
I have tried the 3-step-Meshing: 1. blockMesh a coarse mesh and topoSet a cellSet 2. decomposePar for making it ready for parallel processing 3. mpirun -np 8 refineMesh -overwrite -parallel This works fine until the memory bottleneck was met Now it comes to me a idea that if i can refineMesh one subMesh by one subMesh. I mean, if it is possible that i refine one subMesh once but still parallelly. I guess if the meshing domain could be limited to one subMesh and exploited all cpu cores' power, then the memory needed is affordable for me and the performance is ok. |
June 23, 2016, 02:39 |
Anton Kidess
Rep Power: 30 |
If you run on a single node, of course running in parallel will not gain you anything in terms of memory. If you don't have more than a single node, you are out of luck I think. Yeah, you can mesh subdomains separately and then stich, but you'll probably still dump once you stitch and get the large mesh, or finally when you attempt to solve.
July 4, 2016, 21:09 |
#9 | |
Xiaoqiu HE
Rep Power: 10 |
Grid with huge dimensions | Sadegh.A | Mesh Generation & Pre-Processing | 0 | December 30, 2018 15:23 |
multiphase flow in huge dimensions | Sadegh.A | Main CFD Forum | 0 | December 27, 2018 09:37 |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 14:17 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
Non-uniform grid calculation | Aspens | Main CFD Forum | 1 | February 23, 2000 14:15 |
