July 20, 2016, 08:04 |
Bad Mesh transition
Almond Wong
Rep Power: 9 |
Hi, I am using sHM and wonder if here is a way to specify the transition between the different mesh refinement level.
Attached is the mesh generated with bad transition. Any suggestion of how to improve the mesh quality? Thank in advance for the help, will be greatly appreciated!! |
July 21, 2016, 05:18 |
Joachim Herb
Rep Power: 21 |
What is the output of checkMesh? And are you sure that what you see is not an artifact of paraview. You might try to uncheck the setting "decompose polyhedra" and check the setting "crinkle clip/slice" (if your picture shows a clip or slice)
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[mesh manipulation] cfMesh + extrudeMesh -> bad quality mesh? | aerospacious | OpenFOAM Meshing & Mesh Conversion | 1 | July 28, 2020 02:57 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
