[mesh manipulation] Mesh Problems after extrudeMesh |
June 16, 2015, 19:23 |
Cristina Moreira
Rep Power: 11 |
Greetings,
i want to refine a contour of a structure inside a simple box created using blockMesh. Using Salome, i created the .stl file needed and used Helyx to confirm that everyting was ok. Also, using cellSet i created a zone neer the contour in order to obtain a better refinement. Everything was ok. Only a problem appeared do to fact that i was creating a 3D mesh that in reality was 2D (Ny=1 and ymax=0.01) with blockMeshDict. I was expecting to solve this problem with extrudeMesh but something went wrong. The commands used are: blockMesh setSet -batch setRefin refineMesh -dict system -overwrite surfaceFeatureExtract (with 180º) snappyHexMesh -overwrite ---- till now the only problem was only the 3D that need to be 2D ---- So i run extrudeMesh (as i have done in previously cases) but the mesh appeared with several errors. (see images) extrudeMeshDict: Code:
// What to extrude: // patch : from patch of another case ('sourceCase') constructFrom patch; sourceCase ; sourcePatches (empty1); // If construct from patch: patch to use for back (can be same as sourcePatch) exposedPatchName empty1; // Flip surface normals before usage. flipNormals false; //- Linear extrusion in point-normal direction extrudeModel linearNormal; nLayers 1; expansionRatio 1.0; linearNormalCoeffs { thickness 0.01; } // Do front and back need to be merged? Usually only makes sense for 360 // degree wedges. mergeFaces false; Error message: Code:
cd 15 cristina@cristina-HP-Pavilion-g6-Notebook-PC:~/OpenFOAM/cristina-2.2.2/run/test/15$ checkMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.2-9240f8b967db Exec : checkMesh Date : Jun 17 2015 Time : 11:20:00 Host : "cristina-HP-Pavilion-g6-Notebook-PC" PID : 5172 Case : /home/cristina/OpenFOAM/cristina-2.2.2/run/test/15 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 1693614 internal points: 0 faces: 3359069 internal faces: 1671689 cells: 837421 faces per cell: 6.00744 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 831276 prisms: 186 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 5959 Breakdown of polyhedra by number of faces: faces number of cells 7 5501 8 457 9 1 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 200 402 ok (non-closed singly connected) outlet 400 802 ok (non-closed singly connected) bottom 2617 5238 ok (non-closed singly connected) empty1 1674842 1693614 ok (non-closed singly connected) empty2 0 0 ok (empty) atmosphere 2710 5422 ok (non-closed singly connected) ramp_solid 6611 13224 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 -0.01 -6.96284e-27) (13.95 0.000535259 1) Mesh (non-empty, non-wedge) directions (0 0 0) Mesh (non-empty) directions (0 0 0) ***Number of edges not aligned with or perpendicular to non-empty directions: 20428 <<Writing 26756 points on non-aligned edges to set nonAlignedEdges Boundary openness (2.52486e-18 8.58837e-12 1.05755e-16) OK. Max cell openness = 2.15239e-16 OK. Max aspect ratio = -1 OK. Minimum face area = 4.38e-08. Maximum face area = 6.98e-05. Face area magnitudes OK. Min volume = 2.02056e-10. Max volume = 3.49e-07. Total volume = 0.138252. Cell volumes OK. Mesh non-orthogonality Max: 143.36 average: 1.80463 *Number of severely non-orthogonal (> 70 degrees) faces: 69. ***Number of non-orthogonality errors: 36. <<Writing 105 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 208 faces are incorrectly oriented. <<Writing 172 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 9.84588, 1 highly skew faces detected which may impair the quality of the results <<Writing 1 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 4 mesh checks. End Cristina Last edited by CrisMoreira; June 17, 2015 at 06:21. |
[mesh manipulation] extrudeMesh limits Adaptive/Dynamic Mesh Refinenemt | potentialFoam | OpenFOAM Meshing & Mesh Conversion | 3 | January 29, 2018 03:42 |
[ANSYS Meshing] First layter thickness on mesh causing problems | Rik102 | ANSYS Meshing & Geometry | 0 | November 4, 2016 09:51 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[Commercial meshers] Problems with ANSYS mesh conversion | tdog | OpenFOAM Meshing & Mesh Conversion | 1 | March 31, 2016 17:36 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
