[Other] Wind Turbine
Old   April 16, 2017, 07:29
Default Wind Turbine
Yongqing Xia
yqxia is on a distinguished road
Hello guys, I am using OF 4.0 to build up a simulation for the wind turbine. Now i have meet some difficulties of meshing up the 3D model:
1. I have already build up a 2D wind turbine, which i used case from the 2D-vessel-mixer tutorial case and mixed something from 6-DOF in wingsMotion. Which works well.
-------------------done
https://www.youtube.com/watch?v=IGE4S-cL27I
2. I loaded a STL file of the blade geometry and put it into a cylinder domain by using the SnappyHex.
3. But how can i get that cylinder into a static Cube domain, in which i can give the boundary conditions for the whole domain, and using the AMI as the communication for the cylinder and the Cube?
To make easy: how to build up a Mesh Domain contains a dynamic and a static domain, and the dynamic Domain needs to be SnappyHexed?
-------------------how to do this?
PS: i tried to read the Mixer-vessel tutorial case, which much similar to my case. But i am not be able to understanding the meshing up process in that case.
Any ideas?
I would very much appreciate it.
Yqxia
yqxia is offline   Reply With Quote
ami patches, moving mesh, snappyhexmesh 3d
Air Flow Analysis around a Wind Turbine NightHawkRaven FLUENT 4 August 12, 2014 17:18
simulating a wind turbine s.q FLUENT 1 October 17, 2013 08:11
Ducted wind turbine (BC for the shroud) Pepita CFX 4 June 29, 2013 07:09
Moving reference frame in wind turbine kongl1986 FLUENT 0 March 30, 2013 10:50
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
