Daniela Benites
Rep Power: 9 ![]() |
I am kind of new using OpenFOAM. In OpenFOAM extend (V 4.0) there is a tutorial called pitchingPlate which uses IBM solver. The thing is that the dynamicMeshDict for the plate is for forced motion to do the rotating Oscillation (so you set its amplitude and period) and I am willing to change it to be free to move with the fluid flow until a fixed angle (maybe using damping to try to return to its original position too). The forced motion uses the immersedBoundarySolidBodyMotionFvMesh and I assume I have to use the dynamicMotionSolverFvMesh for free induced motion but then I cannot relate it to my .ftr file. Any ideas? |
immersed boundary method, motion dynamicmesh, pitching plate |
[waves2Foam] Modelling the vertical motion of a completely submerged plate | toodles | OpenFOAM Community Contributions | 0 | July 27, 2016 17:42 |
Trying to model the motion of a submerged plate due to water waves. BC problem. | toodles | OpenFOAM Running, Solving & CFD | 5 | July 19, 2016 05:03 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
pimpleDyMFoam - harmonic motion of a plate - wrong pressure distribution | adii | OpenFOAM | 0 | April 30, 2014 08:28 |
2D airfoil with heaving and pitching motion | zhereal | Fluent UDF and Scheme Programming | 1 | April 13, 2014 15:18 |
