[snappyHexMesh] SnappyHexMesh on multi-STL geometry in foam extend |
April 12, 2016, 21:41 |
#1 | ||
Florian Nguyen
Rep Power: 10 |
Hello friends,
Previously I used OpenFOAM3.0+ to generate a mesh based on 12 separate STL files (the different surfaces that define my patches). In OF30+, the procedure is quite straightforward: Quote:
Any help would be deeply appreciated, thanks for your time guys, Florian |
May 18, 2017, 02:27 |
Deepa Vedartham
Rep Power: 9 |
Hi
I am facing a similar problem. Have you found the solution yet? |
May 18, 2017, 21:24 |
Rep Power: 15 |
Is it not the name of the output .eMesh file? This might be similar to the surfaceFeatureExtract utility that was present in OF2.1, before it was changed to a dictionary based version in OF2.2 Hope this helps. Cheers, Antimony |
December 20, 2017, 15:05 |
snappy problem
Sam
Rep Power: 8 |
Hey guys,
Please any solution to the problem? I use foam-extend 4, and it seems that foam-extend doesn't work with snappyHexMesh. The error I'm getting, first of all it tells me that "meshQualityDict" cannot be read because Code:
Unknown functionEntry 'includeEtc' Code:
keyword debug is undefined in dictionary "$WM_PROJECT_USER_DIR/FluidSolidInteraction/run/fsiFoam/proj/system/snappyHexMeshDict" Sam |
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 07:49 |
[Salome] Salome import "Cannot find file "points" in directory..." | mismichael | OpenFOAM Meshing & Mesh Conversion | 5 | June 22, 2019 02:56 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[snappyHexMesh] What types of stl files are needed in snappyhexmesh? | phandy | OpenFOAM Meshing & Mesh Conversion | 1 | February 19, 2015 05:36 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
