[Salome] salome to Openfoam import
Old   June 4, 2017, 09:53
Post salome to Openfoam import
karundev
krndv is on a distinguished road
hello,
I am new to openfoam and salome, I have generated a model and mesh in salome. Using .unv file, generated the constant folder also.
If I am following this procedure is there a need of 'blockMeshDict' file?
thankyou
krndv is offline   Reply With Quote
Old   July 16, 2017, 00:58
Ali Noaman Ibrahim
alinuman15 is on a distinguished road
Originally Posted by krndv View Post
hello,
thankyou
Leave polymesh files of a case similar to your case (from tutorial for example) as they are and include your .unv file on the top-level case directory. Then run ideasUnvTFoam yourfile.unv
regards
Last edited by wyldckat; August 27, 2017 at 10:26. Reason: fixed broken quote marker
alinuman15 is offline   Reply With Quote
Old   July 16, 2017, 01:12
karundev
Thank you....
Old   July 16, 2017, 01:28
Ali Noaman Ibrahim
Thank you....
My pleasure
cfd, mesh, openfoam, salome
[Salome] Salome body fitting for OpenFOAM case fatirishman53 OpenFOAM Meshing & Mesh Conversion 9 April 10, 2024 14:51
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
Can OpenFOAM currently import CAD geometry? Davitt OpenFOAM Pre-Processing 2 November 2, 2015 07:46
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
