[snappyHexMesh] Snappy Hex Mesh External Domain
Old   June 9, 2017, 01:46
Default Snappy Hex Mesh External Domain
wil
willindsey is on a distinguished road
I am trying to mesh a NACA airfoil and simulate an external flow. I am using snappy hex mesh to mesh the airfoil, but when I run snappy hex mesh the external domain disappears. All that remains is a meshed airfoil. I have tried two methods. The first is just inserting the NACA airfoil into the blockMesh domain. The second is inserting the an external volume with the surface mesh of the airfoil inside. I run the snappy hex mesh with out any errors output. I then look at the mesh in paraFoam, but the external volume on time step 1 and 2 is gone, the only patch there is the airfoil. Any advice would be helpful. Thanks
willindsey is offline   Reply With Quote
Old   June 9, 2017, 02:28
Brian Willis
Dipsomaniac is on a distinguished road
Hi Wil
In your snappyHexMeshDict file, make sure that the locationInMesh coordinates are outside the STL used to mesh the aerofoil. It sounds like you may have chosen a point inside the STL, hence it is only meshing the inside of the aerofoil as opposed to the exterior.
Brian
Dipsomaniac is offline   Reply With Quote
Old   June 9, 2017, 22:03
wil
Thats it. All of the tutorials I found online said to put the location inside the mesh, but they were all for internal flows. Thanks
[blockMesh] FATAL ERROR: face 6 in patch 2 does not have neighbour cell face: 4(8 9 21 20) robingilbert OpenFOAM Meshing & Mesh Conversion 28 November 23, 2023 06:32
[snappyHexMesh] Snappy Hex Mesh - issue with smoothness of the model edges olek.warc OpenFOAM Meshing & Mesh Conversion 1 August 31, 2018 11:31
[snappyHexMesh] Scaling issues with STL file and snappy hex mesh . pradyumnsingh OpenFOAM Meshing & Mesh Conversion 2 July 18, 2018 16:17
Importing snappy hex mesh to fsiFoam Mohammad Jam OpenFOAM Running, Solving & CFD 0 January 28, 2017 19:28
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 10:20
