[surface handling] surfaceFeatureExtract in Foam Extend 3.2
Old   October 7, 2017, 21:08
Default surfaceFeatureExtract in Foam Extend 3.2
Ashish Kumar
ashish.svm is on a distinguished road
I am facing a problem with surfaceFeatureExtract in Foam Extend 3.2
I am using the following command
surfaceFeatureExtract -includedAngle 150 -writeObj constant/triSurface/geom.stl
But it shows this error
--> FOAM FATAL ERROR:
Wrong number of arguments, expected 2 found 1
Invalid option: -writeObj
ashish.svm is offline   Reply With Quote
Old   October 12, 2017, 04:53
Katt
Katt is on a distinguished road
Have you found out how to do this. I am in need of the same for foam-Extend 1.6.
Katt is offline   Reply With Quote
Old   October 12, 2017, 08:54
Ashish Kumar
Originally Posted by Katt View Post
No, I could not figure it out in foam extend version. But I installed OpenFOAM 4.0 and then got it working with surfaceFeatureExtractDict in system folder and then in the command you have to run surfaceFeatureExtract
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
