[Gmsh] unwanted defaultFaces after exporting to foam 5.0 |
June 20, 2018, 14:04 |
Deep
Rep Power: 8 |
Continuing my efforts to tweak the tutorial case here: https://github.com/openfoamtutorials...r/SpaceCapsule. 1. I wanted to create structured mesh in the immediate vicinity of the front side of the object. 2. Also, I wanted to modify the geometry slightly and introduce a smooth corner on the front. I did this in these two steps. Modified the gmsh file a little first to create the hybrid mesh and then to create the corner. When I export the mesh to foam, I get an warning of this sort for both cases: Code:
--> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const cellShapeList&, const faceListList&, const wordList&, const wordList&, const Foam::word&, const Foam::word&, const wordList&, bool) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 595 Found 1146577 undefined faces in mesh; adding to default patch. When I checked in paraview these faces are the ones that I created for the structured region (part of which were present for the first case yet did not result in defaultFaces entry) Can anyone please explain why this is happening? Also, how do I get rid of the defaultFaces? Last edited by deepbandivadekar; June 20, 2018 at 15:57. |
June 20, 2018, 15:54 |
Deep
Rep Power: 8 |
I thought maybe actually visualizing this would help. So here's the script and the mesh for both above cases. https://drive.google.com/open?id=109K42DoIiMBcrsE_7RBxxgRXzUdJ1hN0
Does anyone see what's wrong? Last edited by deepbandivadekar; June 21, 2018 at 12:02. |
June 22, 2018, 11:41 |
It is fine, that you read all warnings, but is there defaultFaces patch in converted mesh? Could you post checkMesh output? Initially gmshToFoam adds ALL boundary faces of the mesh to defaultFaces patch, then it iterates over Gmsh physical groups and moves faces from defaultFaces to corresponding patches. And if in the end defaultFaces has 0 faces, this patch is removed. |
June 23, 2018, 19:16 |
#4 | |
Deep
Rep Power: 8 |
Okay. Well, checkMesh does indicate non-zero defaultFaces for sure and the converted mesh retains the defaultFaces patch. I'm not in front of the machine at the moment but I'll post checkMesh output as soon as I can. |
June 24, 2018, 12:30 |
Deep
Rep Power: 8 |
checkMesh log:
sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 724034 internal points: 0 faces: 2074429 internal faces: 927852 cells: 570553 faces per cell: 5.26205 boundary patches: 8 point zones: 0 face zones: 0 cell zones: 2 Overall number of cells of each type: hexahedra: 149929 prisms: 419736 wedges: 0 pyramids: 475 tet wedges: 0 tetrahedra: 413 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 7 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 with 420377 cells to cellSet region0 <<Writing region 1 with 107221 cells to cellSet region1 <<Writing region 2 with 29351 cells to cellSet region2 <<Writing region 3 with 931 cells to cellSet region3 <<Writing region 4 with 931 cells to cellSet region4 <<Writing region 5 with 361 cells to cellSet region5 <<Writing region 6 with 11381 cells to cellSet region6 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology wedge1 570553 361262 ok (non-closed singly connected) inletExt 74 149 ok (non-closed singly connected) outlet 50 101 ok (non-closed singly connected) vehicle 265 531 ok (non-closed singly connected) wedge0 570553 363434 ok (non-closed singly connected) tunnel 77 156 ok (non-closed singly connected) defaultFaces 4338 6507 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.4625 0 -0.0431832) (1.055 0.989058 0.0431832) Mesh has 2 geometric (non-empty/wedge) directions (1 1 0) Mesh has 3 solution (non-empty) directions (1 1 1) Wedge wedge1 with angle 2.5 degrees Wedge wedge0 with angle 2.5 degrees All edges aligned with or perpendicular to non-empty directions. Boundary openness (2.22698e-18 -9.85001e-15 -3.63658e-14) OK. Max cell openness = 3.06502e-16 OK. Max aspect ratio = 4.93758 OK. Minimum face area = 1.12807e-09. Maximum face area = 0.00223978. Face area magnitudes OK. Min volume = 1.48533e-13. Max volume = 2.19885e-05. Total volume = 0.0647844. Cell volumes OK. Mesh non-orthogonality Max: 41.98 average: 5.90285 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.842296 OK. Coupled point location match (average 0) OK. Mesh OK. End |
June 24, 2018, 12:33 |
#6 | |
Deep
Rep Power: 8 |
These lines are talking about the structured regions of the mesh. Code:
*Number of regions: 7 The mesh has multiple regions which are not connected by any face. |
July 2, 2018, 08:50 |
Deep
Rep Power: 8 |
I had an epiphany to try the original case once again with the current version of Gmsh.
(I had recently upgraded to 3.0.6 from the previous 2.10.0 since I wanted to work with Boolean operations.) As it turns out even for the base case the default faces are created after exporting to OF. Base case doesn't even have any internal faces! So now I know that this is something about Gmsh 3.0.6 and not any error in my script. Problem remains to be resolved. Can anyone see a workaround? This is part of the gmahToFoam export log for base case Code:
Skipping tag at line 483535 Patch 0 gets name wedge0 Patch 1 gets name vehicle Patch 2 gets name outlet Patch 3 gets name inlet Patch 4 gets name wedge1 Patch 5 gets name tunnel --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const cellShapeList&, const faceListList&, const wordList&, const wordList&, const Foam::word&, const Foam::word&, const wordList&, bool) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 595 Found 241757 undefined faces in mesh; adding to default patch. Finding faces of patch 0 Finding faces of patch 1 Finding faces of patch 2 Finding faces of patch 3 Finding faces of patch 4 Finding faces of patch 5 FaceZones: Zone Size Writing zone 0 to cellZone volume and cellSet End |
July 2, 2018, 10:40 |
You can visualise your defaultFaces for every case and then try to deduce why they have appeared (it is your case files, so, in general, you should know more about meshes than people who look at your files). I have attached your default faces for case1.msh and case2.msh. So now you should answer a question: why these faces were not added to any patch? |
July 3, 2018, 16:37 |
#9 | |
Deep
Rep Power: 8 |
But since I now know that I can get around this issue with older Gmsh version am not going to pursue this. |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
