[snappyHexMesh] Scaling issues with STL file and snappy hex mesh .
Old   June 28, 2018, 19:25
Default Scaling issues with STL file and snappy hex mesh .
pradyumnsingh is on a distinguished road
I am very new to OpenFoam
I am trying to put a stl file in domain space created by blockMesh utility.
However , snapping isn't really happening . The mesh generated after snapping dosent really have my model from the stl file. I have scaled both blockMesh and Snappy Hex Dict to 0.001 as mentioned below to mm .
The domain space was very carefully made , i suspect that I am having a scaling issue.
I am also attaching the files. Thanks for taking time to help me out
BloxkMeshDict
backgroundMesh
xMin -260; //
xMax 26;
yMin -5; //
yMax 66;
zMin -5;
zMax 37;
xCells 286;
yCells 71;
zCells 10;
convertToMeters 0.001; // for mm 0.001
SnappyHexMeshDict
geometry
hemisphere.stl
type triSurfaceMesh;
scale 0.001;
name hemisphere;
//refinementBox
//type searchableBox;
//min (-0.5 -0.2 -0.5);
//max (2.5 0.5 2.5);
castellatedMeshControls
maxLocalCells 1000000;
maxGlobalCells 2000000;
minRefinementCells 100;
resolveFeatureAngle 42;
nCellsBetweenLevels 10;
features
file "hemisphere.eMesh";
scale 0.001;
level 1;
refinementSurfaces
hemisphere
// Surface-wise min and max refinement level
level (1 1);
pradyumnsingh is offline   Reply With Quote
Old   July 17, 2018, 11:52
Otavio Duarte Aires Heckler
OtavioDuarte is on a distinguished road
BloxkMeshDict
backgroundMesh
xMin -260; //
xMax 26;
yMin -5; //
yMax 66;
zMin -5;
zMax 37;
xCells 286;
yCells 71;
zCells 10;
SnappyHexMeshDict
geometry
hemisphere.stl
scale 0.001;
name hemisphere;
//refinementBox
features
scale 0.001;
level 1;
refinementSurfaces
hemisphere
level (1 1);
OpenFoam works in meters, be careful with that. In addition, to generate the mesh you need some care, the geometry used must be inside the cube generated by BlockMesh, as close as possible to their faces to be able to converge. Another error is your stl file in binaries, but in snappyHexMesh it is ascii, convert your file to ascii.
OtavioDuarte is offline   Reply With Quote
Old   July 18, 2018, 16:17
Thanks for your reply !
I did figure out the issue a while ago and it was exactly as you said. The stl file was in binaries and I needed to convert it into ASCII . It works like a charm now.
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[snappyHexMesh] Snappy Hex Mesh - issue with smoothness of the model edges olek.warc OpenFOAM Meshing & Mesh Conversion 1 August 31, 2018 11:31
[snappyHexMesh] snappy hex mesh error kd55 OpenFOAM Meshing & Mesh Conversion 14 July 17, 2018 02:13
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] Snappy Hex Mesh Generation: error preventing the .eMesh file generation. Mariana Garcia OpenFOAM Meshing & Mesh Conversion 1 January 7, 2016 04:24
