[snappyHexMesh] Scaling issues with STL file and snappy hex mesh . |
June 28, 2018, 19:25 |
Rep Power: 7 |
I am very new to OpenFoam
I am trying to put a stl file in domain space created by blockMesh utility. However , snapping isn't really happening . The mesh generated after snapping dosent really have my model from the stl file. I have scaled both blockMesh and Snappy Hex Dict to 0.001 as mentioned below to mm . The domain space was very carefully made , i suspect that I am having a scaling issue. I am also attaching the files. Thanks for taking time to help me out BloxkMeshDict backgroundMesh { xMin -260; // xMax 26; yMin -5; // yMax 66; zMin -5; zMax 37; xCells 286; yCells 71; zCells 10; } convertToMeters 0.001; // for mm 0.001 SnappyHexMeshDict geometry { hemisphere.stl { type triSurfaceMesh; scale 0.001; name hemisphere; } //refinementBox //{ //type searchableBox; //min (-0.5 -0.2 -0.5); //max (2.5 0.5 2.5); //} }; castellatedMeshControls { maxLocalCells 1000000; maxGlobalCells 2000000; minRefinementCells 100; resolveFeatureAngle 42; nCellsBetweenLevels 10; features ( { file "hemisphere.eMesh"; scale 0.001; level 1; } ); refinementSurfaces { hemisphere { // Surface-wise min and max refinement level level (1 1); } // } |
July 17, 2018, 11:52 |
#2 | |
Otavio Duarte Aires Heckler
Rep Power: 9 |
July 18, 2018, 16:17 |
#3 | |
Rep Power: 7 |
I did figure out the issue a while ago and it was exactly as you said. The stl file was in binaries and I needed to convert it into ASCII . It works like a charm now. |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] Snappy Hex Mesh - issue with smoothness of the model edges | olek.warc | OpenFOAM Meshing & Mesh Conversion | 1 | August 31, 2018 11:31 |
[snappyHexMesh] snappy hex mesh error | kd55 | OpenFOAM Meshing & Mesh Conversion | 14 | July 17, 2018 02:13 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] Snappy Hex Mesh Generation: error preventing the .eMesh file generation. | Mariana Garcia | OpenFOAM Meshing & Mesh Conversion | 1 | January 7, 2016 04:24 |
