April 27, 2021, 16:06 |
Error ideasUnvToFoam
Luis Sosa
Rep Power: 5 |
Hi everyone! I'm trying to simulate an axial flow compressor using the SRFFoam tutorial in the foam-extend 3.2 version, but when I try to export my SALOME mesh from UNV to FOAM, I get the next message:
Create time Processing tag:164 Starting reading units at line 3. l:1 units:" SI: Meter (newton)" unitType:2 Unit factors: Length scale : 1 Force scale : 1 Temperature scale : 1 Temperature offset : 273.15 Processing tag:2420 Skipping tag 2420 on line 9 Skipping section at line 9. Processing tag:2411 Starting reading points at line 20. Read 360571 points. Processing tag:2412 Starting reading cells at line 721165. First occurrence of element type 11 for cell 1 at line 721166 First occurrence of element type 44 for cell 1201 at line 724766 First occurrence of element type 115 for cell 26001 at line 774366 Read 348000 cells and 24800 boundary faces. Processing tag:2467 Starting reading patches at line 1470368. For group 1 named INLET trying to read 5800 patch face indices. For group 2 named OUTLET trying to read 5800 patch face indices. For group 3 named SSWALL trying to read 800 patch face indices. For group 4 named PSWALL trying to read 800 patch face indices. For group 5 named GROUND trying to read 1200 patch face indices. For group 6 named SLIPERWALL trying to read 7200 patch face indices. For group 7 named PINSS trying to read 800 patch face indices. For group 8 named POUTSS trying to read 800 patch face indices. For group 9 named PINPS trying to read 800 patch face indices. For group 10 named POUTPS trying to read 800 patch face indices. For group 11 named ROTOR trying to read 348000 patch face indices. Sorting boundary faces according to group (patch) --> FOAM FATAL ERROR: 26001 not found in table. Valid entries: 24800 ( 1201 That error only occurs when I make a volume group named "ROTOR". I almost read some threads here in the forum but Ican't find some solution. Can somebody please help me with this error? I'm really desesperate. Thank you so much for your time and help. |
April 28, 2021, 03:03 |
Gerhard Holzinger
Rep Power: 28 |
Make sure you don't have any EdgeGroups in the Salome mesh prior to exporting. ideasUnvToFoam will fail if EdgeGoups are present.
However, I have no idea if this is the cause of your problem. You could also try to use alternative means of exporting the mesh from Salome, e.g.: https://github.com/psicofil/salomeToOpenFOAM https://github.com/nicolasedh/salomeToOpenFOAM |
