[snappyHexMesh] snappyhexmesh cuts small gaps into geometry |
January 2, 2019, 10:57 |
David
Rep Power: 7 |
Hello together,
I am trying to do a hexahedral mesh of a basin with an inclination on one side. My problem is that the edges at the top of the basin don't get cut off properly as you can see in the picture. I've tried to play around with the edge refinement and some angle settings but nothing really worked well as I don't want that edge to be very fine because then it takes to long to run the process. Do you have any suggestions for me? Here's the snappyHexMeshDict. The part is named as "end_wall". The top of the geometry is "outlet". PHP Code:
Last edited by Fool; January 2, 2019 at 13:02. Reason: forget to tell the name of the top layer |
January 2, 2019, 17:22 |
David
Rep Power: 7 |
By the way it does the same even worse at my inlet as you can see in the picture.
inlet.JPG Below I post a picture of the .stl so you can see how it should look. becken.jpg |
January 3, 2019, 07:09 |
ssa
Rep Power: 7 |
I think your blockMesh is too coarse.
January 3, 2019, 07:43 |
David
Rep Power: 7 |
Okay. I'll try to do it with a finer blockmesh. But isn't there another possibility if I don't want a very fine mesh?
January 3, 2019, 10:42 |
#5 | |
Rodrigo
snappyhexmesh |
Joints of a geometry not snapped well (SnappyHexMesh) | malini1408 | OpenFOAM Pre-Processing | 1 | April 15, 2019 12:09 |
[snappyHexMesh] Problem and doubts with blockMesh, snappyHexMesh and multiple geometry | luca1992 | OpenFOAM Meshing & Mesh Conversion | 0 | August 23, 2017 11:40 |
Importing CAD geometry and Editing edges to match | Ahmed | CFX | 15 | March 21, 2016 12:39 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
