[CGNS] Meshing Volume inside volume
Old   February 27, 2019, 10:55
Default Meshing Volume inside volume
Gaetano
bloover is on a distinguished road
Hi everyone, first of all I was looking for a section where to introduce me, but I did not find it, I will do it here.
I'm Gaetano and I'm a student in Palermo University.
I'm trying to make a mesh of a piece of beam with stirrup and bars, but I'm having some trouble with stirrup, it is inside the main domain, and I do not know how to solve it. I'm attaching the .geo file, hoping someone could help. Maybe there are other way to mesh it, I do not know.
Thank you
SetFactory("OpenCASCADE");
// Input
Rectangle(1) = {0, 0, 0, 300, 300, 0};
Disk(2) = {50, 50, 0, 10, 10};
Disk(3) = {50,250,0,10,10};
Disk(4) = {250,250,0,10,10};
Disk(5) = {250,50,0,10,10};
Rectangle(6) = {30,30,146,240,240,10};
Rectangle(7) = {40,40,146,220,220,10};
// Start Operations
s() = BooleanFragments{ Surface{1}; Delete; }{ Surface{2,3,4,5}; Delete;};
ext() = Extrude{0,0,300} {Surface{s()}; Layers{10}; Recombine;};
st() = BooleanFragments{ Surface{6}; Delete;}{Surface{7}; Delete;};
Recursive Delete {Surface{7}; }
Extrude{0,0,10} {Surface{22}; Layers{10}; Recombine;}
BooleanFragments{ Volume{5}; Delete;}{Volume{6}; Delete;}
// Mesh Options all elements needs to be Hexa
Mesh.RecombineAll = 2;
File Type: txt stirrup.txt (738 Bytes, 0 views)
bloover is offline   Reply With Quote
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[Gmsh] 3D coil mesh: can't create the volume? RomainBou OpenFOAM Meshing & Mesh Conversion 3 July 18, 2016 05:09
Meshing Volume in Gambit for a water turbine Zaqie FLUENT 1 July 24, 2009 01:25
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
