[snappyHexMesh] Boundary Layer on a lower wall |
Federica Fregosi
Rep Power: 7 ![]() |
Hi everyone,
I have a problem with the generation of a boundary layer on a wall. I am using the snappyHexMesh utility to define my domain around a rudder, and it works on it (it generates the layers and so on). This rudder lays on the lower wall. Now, I am trying to create layers on this lower wall, but I am not sure I am correct. At first I did this: relativeSizes false; layers { rudder { nSurfaceLayers 5; } lowerWall { nSurfaceLayers 5; } } expansionRatio 1.5; thickness 0.016; minThickness 0.0001; But it does not cover all the lower wall (just the refined region). So, I added a new snappyHexMesh just for the lower wall, and in this way it covers all the lower wall but…the simpleFoam does not work! (In the previous way simpleFoam works, but I am not sure it generates the correct results). Obviously, I changed all the boundary conditions (based on the motorBike case): - In the blockMeshDict lowerWall is type wall - K lowerWall { type kqRWallFunction; value $internalField; } - nut lowerWall { type nutkWallFunction; value uniform 0; } - omega lowerWall { type omegaWallFunction; value $internalField; } - p lowerWall { type zeroGradient; } - U lowerWall { type noSlip; /*fixedValue; value $internalField;*/ } In the U conditions I have tried both types. Then, I have tried to understand the motorBike case but it is not clear, for example, the wallBoundedStreamLines dictionary. Any suggestions? Thanks, Best regards |
boundary layer, snappyhesmeshdict, wall |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
