[snappyHexMesh] MultiRegion(Snappy): how to define new zones |
June 12, 2015, 03:52 |
Rep Power: 11 |
Hi everybody,
My case is..... The model consists in one cylinder inside a athmospheric domain ( 3D ). The mesh has been generated by SHM and the geometry of the cylinder is a stl. The model is a multiRegion because the cylinder is solid and the domain is air. I want to define three cellZones on the cylinder, top, bot and wall. I started to define these in the stl file: cylinder.stl Code:
solid top ... ensolidtop solid bot ..... endsolid bot solid wall ..... endsolid wall cyliner_top cyliner_top_slave cylinder_bot cylinder_bot_slave cylinder_wall cylinder_wall_slave But, when I used splitMeshRegions..( splitMeshRegions -cellZones -overwrite) ... I obtained: cylinder_to_domain0 and domain0_to_cylinder. I have seen in the cellZone file, the top,bot and wall don't exist....are only boundaries. I would like to have others cellzones after splitMeshRegion: cylinder_top_to_domain0 cylinder_bot_to_domain0 cylinder_wall_to_domain0 domain0_to_cylinder_top ......etc The target is to define thermal conditions in these patchs. Any idea? Thanks Greetings |
June 12, 2015, 05:55 |
amine
Rep Power: 12 |
I think It's possible by using toposet. toposetDit file like this: you can alson create your air zone N.B: I have creat three STL file Code:
FoamFile { location "system"; class dictionary; object topoSetDict; format ascii; version 2.0; } actions ( { name bot; type cellSet; action new; source surfaceToCell; sourceInfo { file "constant/triSurface/bot.stl"; outsidePoints ((0 0 0)); includeInside true; includeOutside false; includeCut true; nearDistance -1; curvature -100; } } { name bot; type cellZoneSet; action new; source setToCellZone; sourceInfo { set bot; } } { name top; type cellSet; action new; source surfaceToCell; sourceInfo { file "constant/triSurface/top.stl"; outsidePoints ((0 0 0)); includeInside true; includeOutside false; includeCut true; nearDistance -1; curvature -100; } } { name top; type cellZoneSet; action new; source setToCellZone; sourceInfo { set top; } } { name wall; type cellSet; action new; source surfaceToCell; sourceInfo { file "constant/triSurface/wall.stl"; outsidePoints ((0 0 0)); includeInside true; includeOutside false; includeCut true; nearDistance -1; curvature -100; } } { name wall; type cellZoneSet; action new; source setToCellZone; sourceInfo { set wall; } } // clear To cellSet { name air; type cellSet; action clear; } // new To cellSet { name air; type cellSet; action new; // Copy elements from cellSet source cellToCell; sourceInfo { set top; } } // add To cellSet { name air; type cellSet; action add; // Copy elements from cellSet source cellToCell; sourceInfo { set wall; } } // add To cellSet { name air; type cellSet; action add; // Copy elements from cellSet source cellToCell; sourceInfo { set bot; } } // invert To cellSet { name air; type cellSet; action invert; } // new To cellZoneSet { name air; type cellZoneSet; action new; // Select based on cellSet source setToCellZone; sourceInfo { set air; // name of cellSet } } ); |
June 16, 2015, 05:52 |
Rep Power: 11 |
Hi aminem,
It's a nice idea, but I haven't achieved my target. This is a simple model, because I will do a multiRegion simulation. I've loaded a image, which depicts three regions (fluid and solids), this is the complex model. I need to carry out snappy and splitMeshRegion,.. I tried your proposal, before SMR......but after SMR, the cylinder's BC (top, wall and bot) were not defined..... I only obtained one BC, cylinder_to_domain0. To sum up, I want to define three BC on a cylinder, which is inside 2 domains/regions. And the principal requirement is that the model have to be built using snappy and splitMeshRegion. But I can use topoSet or other... Thanks. |
June 26, 2015, 05:52 |
amine
Rep Power: 12 |
Hi
Do you have found a solution? Thanks |
June 26, 2015, 06:24 |
Rep Power: 11 |
Hi!
I haven't still found a solution..... because now, it isn't an important requirement for my model. But, in the future, I'll have to resolve it and if I find a solution, I'll write a post. Thanks! |
May 3, 2019, 11:47 |
SC
Rep Power: 7 |
Hi
Did you found any solution? I have a similar problem on my case. It's a design of a heat exchanger. I tried to load at SHM the whole surface (multiregion stl file). Within that surface lies regions where i wanted to create cellZones. My questions is basically, is it possible to create cellZones coming from patches defined at 'refinementSurfaces' at SHM? --- I already tried to build this case with two different stl (one for the solid region and another for the fluid region). But after the snap it either creates a lot of other domains or it just cuts off the fins which is the interception between the two surfaces. |
May 3, 2019, 12:02 |
SC
Rep Power: 7 |
Just attached the geometry
There's and inlet and outlet pipe and a main (transparent) domain. These are all fluid, which represents the water through the heat exchanger. And there's the solid domain which has the fins along the board and the outer plate. The problem is between the fins and the main domain. The fins get cut off at the snap or it creates other domains. I'm not sure if it's just a refinement problem, or maybe i should just increase the blockMesh refinement level. Any advice and suggestions are welcome. |
Hydrogen storage by metal hydride | longbk | FLUENT | 12 | August 1, 2023 20:13 |
Different define of psi uesd in pEqn.H | zqlhzx | OpenFOAM Running, Solving & CFD | 0 | December 24, 2013 08:45 |
Robin B.C. | Yu | FLUENT | 3 | May 27, 2012 04:19 |
Defining dynamic zones for Define CG motion | aamer | Main CFD Forum | 0 | March 21, 2011 03:51 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
