[snappyHexMesh] Running Snappyhexmesh in Parallel missing trisurface
Old   June 7, 2019, 06:09
Default Running Snappyhexmesh in Parallel missing trisurface
Florian
Archoncomando is on a distinguished road
Hello there,
im trying to Mesh a Hydrofoil in a Square domain using Snappy Hex Mesh. So far i've gotten along fine but when i try to run SnappyHexMesh in parallel i run into issues.
According to all Tutorials i've read it should work like this:
1. blockMesh
2. surfaceFeatureExtract
3. decomposePar
4. mpirun -np n snappyHexMesh -parallel
However when i start the snappyHexMesh run it immediately quits out on me with this error message from each of the 16 processors:
[0] --> FOAM FATAL ERROR:
[0] Cannot find triSurfaceMesh starting from "/home/rieth/Snappyhex/processor0/constant/triSurface/Fluegel.stl"
[0]
[0]     From function triSurfaceMesh::checkFile(const fileName&, const fileName&)
[0]     in file searchableSurface/triSurfaceMesh.C at line 116.
[0]
FOAM parallel run exiting
Looking at the processor directories individually only the polymesh folder gets split. It doesn't even create a trisurface folder in the processor directories.
I'm using OpenFOAM 2.3.1
Any help would be appreciated
Archoncomando is offline   Reply With Quote
Old   June 10, 2019, 22:08
Yehezkiel Wiliardy
yewi is on a distinguished road
can you post your snappyHexMesh dict and the items inside polyMesh/triSurface?
see if you set it up correctly
also, since you do SFE, have you put the obj in the features?
mpirun -np n snappyHexMesh -overwrite -parallel
cheers,
yewi
yewi is offline   Reply With Quote
Old   June 11, 2019, 05:27
Florian
Hello there!
Here's my snappyhex:
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    Fluegel.stl
        type triSurfaceMesh;
        name part1;
        patchInfo
            type wall;
   water
      type    searchableBox;
          min     (-153.6 -24 -0.80);
          max     (14.4 24 -0.7);
     box1
      type    searchableBox;
          min     (-153.6 -24 -1);
          max     (14.4 24 -0.5);
     box2
      type    searchableBox;
          min     (-153.6 -24 -1.3);
          max     (14.4 24 -0.2);
     box3
      type    searchableBox;
          min     (-153.6 -24 -1.6);
          max     (14.4 24 0.1);
     box4
      type    searchableBox;
          min     (-2 -2 -1.7);
          max     (2 2 1.2);
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 1000000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 200000000;
    // The surface refinement loop might spend lots of iterations refining just a
    // few cells. This setting will cause refinement to stop if <= minimumRefine
    // are selected for refinement. Note: it will at least do one iteration
    // (unless the number of cells to refine is 0)
    minRefinementCells 1;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 1;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
             file "Fluegel.eMesh";
             level 7;
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
        part1
            // Surface-wise min and max refinement level
            level (5 7);
    resolveFeatureAngle 15;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
    water
          mode inside;
          levels ((1e30 4));
    box1
          mode inside;
          levels ((1e30 3));
    box2
          mode inside;
          levels ((1e30 2));
    box3
          mode inside;
          levels ((1e30 1));
        box4
          mode inside;
          levels ((1e30 6));
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    locationInMesh (0 0 0.1);
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 3;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    //    tolerance 4.0;
    tolerance 1.0;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 500;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 15;
    nFeatureSnapIter 20;
// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
    // Per final patch (so not geometry!) the layer information
    layers
        part1
            nSurfaceLayers 5;
    // Expansion factor for layer mesh
    expansionRatio 1.25;
    // Wanted thickness of final added cell layer. If multiple layers
    // is the thickness of the layer furthest away from the wall.
    // Relative to undistorted size of cell outside layer.
    // See relativeSizes parameter.
    finalLayerThickness 0.003;
    // Minimum thickness of cell layer. If for any reason layer
    // cannot be above minThickness do not add layer.
    minThickness 0.0009;
    // If points get not extruded do nGrow layers of connected faces that are
    // also not grown. This helps convergence of the layer addition process
    // close to features.
    // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
    nGrow 0;
    // Advanced settings
    // When not to extrude surface. 0 is flat surface, 90 is when two faces
    // are perpendicular
    featureAngle 60;
    // Maximum number of snapping relaxation iterations. Should stop
    nRelaxIter 5;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 1;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 3;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.5;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
    minMedianAxisAngle 90;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 50;
    // Max number of iterations after which relaxed meshQuality controls
    // get used. Up to nRelaxIter it uses the settings in meshQualityControls,
    // after nRelaxIter it uses the values in meshQualityControls::relaxed.
    nRelaxedIter 20;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    #include "meshQualityDict"
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
My trisurface folder only contains an STL File that i'd rather not share online if possible. My professor is a bit touchy on the subject.
What do you mean by "putting in the features"? I'm a bit confused by this comment.
Old   June 11, 2019, 07:07
Yehezkiel Wiliardy
Hi i cant seem to reproduce the error. My first guess is the stl has problem (maybe bad faces or corrupted).
Secondly,
This is how i normally put my geometry setting in my snappy dict
    Fluegel.stl
        name part1;
        regions
          part1{ name part1; }
Thirdly, the stl regions might not be named correctly?
if you open the stl file there should be part1 at the start and end region block
for example, for Fluegel.stl should be formatted like this
solid part1
  facet normal 0 -0 -1
    outer loop
      vertex -4.302980899810791 21.648529052734375 5.3000001907348633
      vertex -4.302980899810791 20.148529052734375 5.3000001907348633
      vertex -4.9029808044433594 20.148529052734375 5.3000001907348633
    endloop
  endfacet
    outer loop
      vertex -4.9029808044433594 21.648529052734375 5.3000001907348633
    endloop
  endfacet
endsolid part1
Hope these might help
The features is this line:
    features
             level 7;
which seems correct
you might want to specify this inside the snap control, which currently missing in your snappy dict
snapControls
    implicitFeatureSnap false;
    explicitFeatureSnap true; //snaps to manually generated feature edges, reads the features block
Old   June 11, 2019, 07:13
Florian
Hm the thing is if i just run the snappy hex mesh on one core it works fine and produces a Mesh that at least in paraview seems to function correctly. However that takes something like 58000 seconds to generate so it's not all that feasible for comparing different angles of attack etc.
However when i try to cut that time down by running snappy in parallel i get the issue described in my initial post. It seems to want to use a trisurface file in the decomposed processor files but the decompose method doesn't produce those. It seems to only decompose the backround blockMesh but not the trisurface folder.
Old   June 11, 2019, 07:32
Yehezkiel Wiliardy
I see. Hmm this might sound stupid, but what if you manually copy the triSurface folder into each proc folder. Because Ultimately thats what the error seems to demand. Start with small number of procs like 4 and not 16, just to see whether it would work
Old   June 11, 2019, 07:43
Florian
I'll try that but i think it has something to do with the computer cluster not reading the file correctly. Just now i got it to run in parallel on my laptop. Sadly that's only 2 cores.
Trying it on the universities cluster even surfaceextract gives me an error of not being able to read the STL file. You wouldn't happen to have an idea on how to fix that?
Btw thanks for the answers so far!
Old   June 25, 2020, 01:05
Default try this
Chaewoong Ban
blue8803 is on a distinguished road
decomposePar -copyZero
(I use of5 or fe41)
blue8803 is offline   Reply With Quote
decomposepar, missing, snappyhexmesh, trisurface
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 04:38
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 16:38
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
Fluent 14.0 file not running in parallel mode in cluster tejakalva FLUENT 0 February 4, 2015 07:02
Running CFX parallel distributed Under linux system with loadleveler queuing system ahmadbakri CFX 1 December 21, 2014 04:19
