[snappyHexMesh] OpenFoam problem with generation mesh |
June 23, 2019, 15:51 |
Anna
I am new in OpenFoam. I have to generate a mesh on blood vessels model in the brain. I readed that I can do it using blockMesh and then snappyHexMesh. My model has 3 inlet and 10 outlet. For start I divided model for 4 blocks (for easy understand). I readed also that the snappyHexMesh will work only on the block the locationInMesh is in. So I wanted to generated four difrent mesh and then connecting it (if it can ?). But when I set locationInMesh for first block I get a lot of mistakes using snappyHexMesh and I don't know how to solve it....Could someone help me ? |
June 24, 2019, 03:23 |
Yann
Rep Power: 26 |
Hello Anna,
It's going to be hard to help you without knowing exactly what kind of problems you're facing. You should at least post your snappyHexMeshDict file and a log file showing the errors you get when you try to execute snappyHexMesh. See how to give enough information to get help. Yann |
blockmesh, mesh, openfoam, snappyhexmesh |
[ANSYS Meshing] Airfoil edge sizing mesh generation problem | Kostas_K | ANSYS Meshing & Geometry | 0 | March 6, 2017 13:50 |
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
[blockMesh] Problem with mesh generation | Silvy | OpenFOAM Meshing & Mesh Conversion | 12 | July 12, 2015 16:10 |
Geometry and mesh generation in OpenFoam | pokeng | OpenFOAM Pre-Processing | 1 | October 28, 2011 21:40 |
