[mesh manipulation] refine mesh based on skewness
Old   July 16, 2019, 07:01
Default refine mesh based on skewness
Ali Shayegh
amuzeshi is on a distinguished road
Hi
I'm on simulation of an elastic square prism. Results are obtained to some time, then the solver (solids4Foam) crashes. The reason is that the highlighted cell(s) shown in the figure below becomes concave. (Note: Fluid region mesh is shown only.)
Is there any way for run-time mesh refinement according to skewness in order to figure out this difficulty?
regards
Ali
amuzeshi is offline   Reply With Quote
Old   July 16, 2019, 07:46
Ali Shayegh
I know that the two classes dynamicMotionSolverFvMesh and dynamicRefineFvMesh can be combined into one class[1]. However, as it is needed to compile a new solver and initialize the skewness field in its *.H file, there remain two main problems:
1- As solids4Foam does not obey solver-oriented programming discipline in regular openfoam, where to declare skewness?
2- How to declare skewness as -to the best of my knowledge- it is not a volScalarField.
regards
Ali
Ref:
[1] Adaptive Mesh Refinement with a Moving Mesh using sprayDyMFoam
Old   July 17, 2019, 15:04
Ali Shayegh
I know that OpenFOAM defines skewness for faces, not for cells. But I want to refine the mesh based on a user-defined skewness:
cell skewness = max [ ( thetaMax - 90) / 90 , ( 90 - thetaMin) / 90]
Old   January 29, 2024, 06:15
Alejandro
ancolli is on a distinguished road
Hi, have you been able to solve your problem? Is there anything you'd like to share?
Kind regards
ancolli is offline   Reply With Quote
Old   January 29, 2024, 12:17
Ali Shayegh
Kind regards
Hi
For a similar problem, I use manual re-meshing, so, when the simulation crashes, I start off the latest available time using a new mesh.
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 10:11
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
Coarsen and refine mesh in Pointwise raye_xie Pointwise & Gridgen 3 June 26, 2017 17:35
Skewness , Minimum Edge Length and Mesh Quality in FLuent ViLaks FLUENT 2 March 2, 2017 05:57
