[snappyHexMesh] searchablePlane in snappyHexMesh
Old   May 17, 2014, 04:42
Exclamation searchablePlane in snappyHexMesh
zandi's Avatar
Fatema Zandi Goharrizi
zandi is on a distinguished road
Hi everybody
I'm doing an example of flow over a spillway in OF 2.3.0
and preparing mesh with snappyHexMesh
in dfining "geometery" by guidence of a book I itroduced a part in order to refine mesh in the next steps. this part has been introduced as a plane and defined by type of "searchablePlane" in that book.
but an error comes up with it as seen below:
--> FOAM FATAL IO ERROR:
keyword planeType is undefined in dictionary "/home/zandi/OpenFOAM/zandi-2.3.0/run/airent22-3-93/system/snappyHexMeshDict.geometry.onSlope"
file: /home/zandi/OpenFOAM/zandi-2.3.0/run/airent22-3-93/system/snappyHexMeshDict.geometry.onSlope from line 38 to line 44.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 437.
FOAM exiting
I have searched cfd-online and openFoam wiki and help manual inorder to find about such geometry, but there were no such keywords (searchablePlane).
could you please help me with that?
zandi is offline   Reply With Quote
Old   May 26, 2014, 13:02
zandi's Avatar
it has been solved
Old   August 26, 2019, 20:44
Pu Gong
minecraftgp is on a distinguished road
Hi zandi,
Can you tell how did you solve this? I met the same problem when Im trying to sample the field of a plane using sampledict. The error shows
keyword planeType is undefined in dictionary "/home/minecraftgp/openFoam_case/6.3closedFillingBox/6.3.1singlePlumeTracerPosition/bbpf_sp_tracer1_t3720/system/sampleDict.surfaces"
Cheers
minecraftgp is offline   Reply With Quote
refine mesh, searchableplane, snappyhexmesh
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
Strange Results With snappyHexMesh calebamiles OpenFOAM Running, Solving & CFD 0 August 14, 2011 16:02
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
