[snappyHexMesh] Urgent
Like Tree1Likes
  • 1 Post By Carlo_P
Old   October 7, 2019, 01:04
Default Urgent
cyberpr123 is on a distinguished road
Hello all,
I am new to OpenFOAM, I am trying to generate mesh using snappyHexMesh.
I realised that castellated mesh is not working properly.
If I keep it ON or OFF; meshing are still same. Can you help me what is wrong in it?? Also, if i increase level of refinement, there is error, and the meshing aborted.
refinementSurfaces
hull
level (2 2);
This is my SHM code-
#includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg"
castellatedMesh on;
snap on;
addLayers on;
geometry
hull
type triSurfaceMesh;
file "hull.stl";
patchInfo {
type wall;
castellatedMeshControls
features
{ file "hull.eMesh"; level 6; }
refinementSurfaces
hull
level (2 2);
resolveFeatureAngle 60;
refinementRegions
//inside , outside , distance
CAD
mode inside;
levels ((1E15 5));
locationInMesh (1.5 1 0); // Offset from (0 0 0) to avoid
// coinciding with face or edge
//nCellsBetweenLevels 3;
snapControls
// explicitFeatureSnap true;
// implicitFeatureSnap false; // by default
addLayersControls
layers
"hull.*"
nSurfaceLayers 6;
// top
// nSurfaceLayers 5;
relativeSizes true; // false, usually with firstLayerThickness
expansionRatio 1.2;
finalLayerThickness 0.002;
minThickness 1e-4;
// firstLayerThickness 0.01;
// maxThicknessToMedialRatio 0.6;
meshQualityControls
minTetQuality -1e+30;
writeFlags
// scalarLevels
layerSets
layerFields
mergeTolerance 1e-6;
cyberpr123 is offline   Reply With Quote
Old   October 7, 2019, 04:33
Carlo_P
Carlo_P is on a distinguished road
Are you running snappyHexMesh -overwrite?
snappyHexMesh creates different mesh in idfferent timestep (folder), 0 (castelled), 1 (snap), 2 (boundary layer).
You have to open in paraview e move with the timestep.
Otherwise, you can run snappyHexMesh -overwrite and snappy will create the mesh in the normal folder
Carlo_P is offline   Reply With Quote
Old   October 7, 2019, 04:38
Carlo_P,
Thanks for your prompt reply. I did not use snappyHexMesh -overwrite, I would use it and see .
Thank you so much.
Old   October 9, 2019, 08:09
Carlo_P,
Using snappyHexMesh -overwrite worked.
Thank you
Old   October 9, 2019, 08:26
Carlo_P
Great!
If you want to add a reputation point, I will appreciate
cyberpr123 likes this.
urgent!!! mesh and geometry melek FLOW-3D 0 August 26, 2013 10:10
Urgent - Polyflow - particle tracking visualization -Urgent shafaatht ANSYS 0 October 13, 2010 04:56
Urgent, Urgent, a UDF problem, PLEASE HELP!!! Max FLUENT 1 September 24, 2010 20:30
Urgent...urgent...plss!!! astronome FLUENT 0 October 16, 2009 07:17
tmerge urgent urgent jessica FLUENT 4 July 15, 2006 13:37
