[blockMesh] How to solve has input inward-pointing faces |
October 25, 2019, 02:38 |
Jason.H
Rep Power: 7 |
hello, I'd like to make hemisphere domain.
*************************/ R 38.1E-03; deg1 4.0; Lx #calc "3*$R"; x0 #calc "-$Lx"; x1 #calc "-$R"; x2 #calc "-$Lx*cos($deg1)"; x3 #calc "-$R*cos($deg1)"; x4 0; y0 0; y1 $R; y2 $Lx; y3 #calc "$R*sin($deg1)"; y4 #calc "$Lx*sin($deg1)"; z0 0; z1 1E-03; //point on curve-R deg0 20.0; deg2 2.0; rx0 #calc "$R*cos($deg0)"; ry0 #calc "$R*sin($deg0)"; rx1 #calc "$Lx*cos($deg0)"; ry1 #calc "$Lx*sin($deg0)"; rx2 #calc "$R*cos($deg2)"; ry2 #calc "$R*sin($deg2)"; rx3 #calc "$Lx*cos($deg2)"; ry3 #calc "$Lx*sin($deg2)"; convertToMeters 1; vertices ( ($x0 $y0 $z0)//0 ($x1 $y0 $z0)//1 ($x3 $y2 $z0)//2 ($x4 $y1 $z0)//3 ($x4 $y4 $z0)//4 ($x2 $y3 $z0)//5 ($x0 $y0 $z1)//6 ($x1 $y0 $z1)//7 ($x3 $y2 $z1)//8 ($x4 $y1 $z1)//9 ($x4 $y4 $z0)//10 ($x2 $y3 $z0)//11 ); blocks ( hex (2 3 4 5 8 9 10 11) (200 400 1) simpleGrading (1 1 1) hex (1 2 5 0 7 8 11 6) (200 400 1) simpleGrading (1 1 1) ); edges ( arc 2 3 ($rx0 $ry0 $z0) arc 8 9 ($rx0 $ry0 $z1) arc 5 4 ($rx1 $ry1 $z0) arc 11 10 ($rx1 $ry1 $z1) arc 1 2 ($rx2 $ry2 $z0) arc 7 8 ($rx2 $ry2 $z1) arc 0 5 ($rx3 $ry3 $z0) arc 6 11 ($rx3 $ry3 $z1) ); boundary ( axi { type symmetryPlane; faces ( (0 6 7 1) ); } wall { type wall; faces ( (1 7 8 2) (2 8 9 3) ); } out { type patch; faces ( (10 4 3 9) ); } in { type patch; faces ( (0 5 11 6) (5 4 10 11) ); } front { type empty; faces ( (6 7 8 11) (11 8 9 10) ); } back { type empty; faces ( (0 1 2 5) (5 2 3 4) ); } ); mergePatchPairs ( ); but I don't know what is the real problem of this...??? I just dived one body into two part. Pleas help this... --> FOAM Warning : From function Foam::vector Foam::cellModel::centre(const labelList&, const pointField&) const in file meshes/meshShapes/cellModel/cellModel.C at line 70 zero or negative pyramid volume: -1.680368821e-06 for face 1 --> FOAM Warning : From function Foam::vector Foam::cellModel::centre(const labelList&, const pointField&) const in file meshes/meshShapes/cellModel/cellModel.C at line 70 zero or negative pyramid volume: -5.00112815e-07 for face 2 --> FOAM Warning : From function Foam::vector Foam::cellModel::centre(const labelList&, const pointField&) const in file meshes/meshShapes/cellModel/cellModel.C at line 70 zero or negative pyramid volume: -1.158958419e-06 for face 3 --> FOAM Warning : From function Foam::vector Foam::cellModel::centre(const labelList&, const pointField&) const in file meshes/meshShapes/cellModel/cellModel.C at line 70 zero or negative pyramid volume: -1.05676112e-06 for face 4 --> FOAM Warning : From function Foam::vector Foam::cellModel::centre(const labelList&, const pointField&) const in file meshes/meshShapes/cellModel/cellModel.C at line 70 zero or negative pyramid volume: -1.05676112e-06 for face 5 --> FOAM FATAL IO ERROR: Block hex (1 2 5 0 7 8 11 6) (200 400 1) simpleGrading (1(1) 1(1) 1(1)) has inward-pointing faces 4(2 5 11 8) 4(1 2 8 7) 4(0 6 11 5) 4(1 0 5 2) 4(7 8 11 6) FOAM exiting Last edited by gns4566; October 25, 2019 at 09:21. |
October 25, 2019, 03:10 |
Kmeti Rao
Rep Power: 8 |
Hey GNS,
you have forgotten to add the picture! if you add someone would help you |
October 25, 2019, 05:18 |
Mikko
Rep Power: 12 |
Without more information, my best guess is that the vertices of the block are in wrong order.
October 25, 2019, 09:20 |
Jason.H
Rep Power: 7 |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 07:05 |
[snappyHexMesh] SHM is not extruding/adding Layers everywhere | matthiasd | OpenFOAM Meshing & Mesh Conversion | 2 | October 16, 2016 16:45 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
