[surface handling] Centrifugal Pump MRF-setup - split/intersect stl surfaces into several patches
Old   November 20, 2019, 10:03
Default Centrifugal Pump MRF-setup - split/intersect stl surfaces into several patches
.bastian is on a distinguished road
Hi
I try to set up a centrifugal pump as a mrf case. My model consists of two stl-files each for the rotor and one for the stator region. As you can see in picture 1, each stl file contains named surfaces for the walls, inlets and outlets.
Meshing is done with cfmesh separated for the rotor and the stator with a final merging to a single mesh and a setup of the cell-zones.
If i try to run the full setup case with the rotor outflow section and the stator inlet section as neighbour patches of an cylindricAMI interface simpleFoam exits with "FOAM FATAL ERROR: Unable to set source and target faces" while creating the "adressing and weights between the [AMI] source and target faces".
I assume the problem is that the trailing edges of the blades are not modelled (picture 3) and the neighboring patches are not completely the same. (gaps at the trailing edge positions)
So is there a way to split the inflow face of the stator into a fluid inflow region and the blade trailing edge (walls)?
Maybe by an intersection/splitting of the two stl surfaces?
I appreciate your help.
.bastian is offline   Reply With Quote
Old   November 29, 2023, 12:39
Pedro Gouveia
unilord is on a distinguished road
Originally Posted by .bastian View Post
Hi
Hey,
Did you manage to solve that problem? I am facing the same issue, but the only solution I came up with was to further the impeller domain (MRF zone) so the tip face would get into the domain. However, that induces some errors, since I will put also a part of the water fluid outside the impeller on rotation.
Regards,
PG
unilord is offline   Reply With Quote
centrifugal pump, cfmesh, intersection surface mesh, mrf simplefoam, stl mesh
Strange Result of ERCOFTAC Centrifugal Pump MRF case in OF2.2.x Ohbuchi OpenFOAM Running, Solving & CFD 10 May 10, 2015 03:47
Centrifugal Pump Simulation Problem! warex FloEFD, FloWorks & FloTHERM 29 September 23, 2014 10:27
centrifugal pump Chalghoum CFX 18 April 16, 2014 06:37
problem for centrifugal pump transient simulation renyun0511 OpenFOAM Running, Solving & CFD 8 January 15, 2014 04:55
simulating a submerged double impeller centrifugal pump sandy_1982 CFX 5 August 16, 2013 09:05
