[mesh manipulation] Stitchmesh with SHM crashing |
February 6, 2020, 08:37 |
#1 | |
Kmeti Rao
Rep Power: 8 |
Dear Foamers,
I am trying to compare the results of MRFSimpleFoam and pimpleDyMFoam. For the ease of setup, I am using propeller tutorial available with OpenFOAM - 6. To implement MRF, I have retained mesh settings as it is and only made few changes to the Allmesh script. After SHM step, I have defined 'stitchMesh -partial innerCylinderSmall innerCylinderSmall_slave'. But the process is stopping by throwing the following error. I have tried with different refinement settings near the interface, but the result is same. Quote:
It would be great if you can provide some valuable inputs, so that I can work in the right direction. Thank you all! K. Rao |
February 10, 2020, 08:00 |
anonymous
Rep Power: 14 |
Hi!
I'm not sure if it is clear for me, but you wanna stitch the mesh on the cyclic interface, right? Then just skip the topoSet and createPatch parts (this is what you would like to undo with the stitch, right?) and modify the case as you wish. |
February 10, 2020, 11:19 |
#3 | |
Kmeti Rao
Rep Power: 8 |
Hi Simrego,
Thank you for your valuable input. This is absolutely true with OpenFOAM 7. I was using openFoam 6, and the patches were created during snappy hex mesh phase. Therefore I have commented out the following lines from SHMdict. Now I can run simpleFoam with MRF. Quote:
mesh manipulation, mrf simplefoam, propeller, snapphhexmesh, stitchmesh |
[mesh manipulation] stitchMesh: multiple meshes | GerhardHolzinger | OpenFOAM Meshing & Mesh Conversion | 3 | August 25, 2017 12:43 |
[mesh manipulation] StitchMesh sigFpe / bad point | liquidspoon | OpenFOAM Meshing & Mesh Conversion | 2 | November 29, 2015 14:19 |
[snappyHexMesh] troubles with sHM and parallel | Tobi | OpenFOAM Meshing & Mesh Conversion | 1 | August 30, 2012 17:54 |
[snappyHexMesh] Multi Region Meshing with sHM | marango | OpenFOAM Meshing & Mesh Conversion | 3 | March 27, 2012 00:51 |
[mesh manipulation] stitchMesh | dhruv | OpenFOAM Meshing & Mesh Conversion | 13 | February 23, 2012 17:14 |
