[snappyHexMesh] Decomposed sHM runs slower than on single thread
Old   February 19, 2020, 11:31
Default Decomposed sHM runs slower than on single thread
Tom
datTommyGuy is on a distinguished road
I'm meshing a more-or-less cylindrical geometry (screenshot attached below, flow through a duct) with sHM. I used a simple (2 2 2) decomposition in decomposeParDict ((2 2 1) for 4 threads). I'm running the case in this order:
blockMesh
surfaceFeatures
decomposePar
mpirun -np 8 snappyHexMesh -overwrite -parallel
However, the more cores I use, the slower snappyHexMesh runs. Just adding new boundary patches takes too long to let it finish the job.
I'm using Ubuntu 16.04 LTS on Windows 10. The processor is a 4-core (8 threads) i7-7700HQ. When using 8 threads, the CPU usage jumps to 100%, while with 4 it stays at about 60%, so the decomposition itself seems to be working.
What may be the cause of such behaviour? I'll gladly provide more details as needed.
datTommyGuy is offline   Reply With Quote
Old   February 19, 2020, 17:29
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
how many cells per processor?
HPE is offline   Reply With Quote
Old   February 20, 2020, 13:30
mzzmrt is on a distinguished road
This is perfectly normal because your processor has 4 real cores so your max parallelization limit is 4!
mzzmrt is offline   Reply With Quote
Old   February 23, 2020, 07:31
Tom
~3000 after blockMesh, limit in sHM set to 0.8*10^6.
I weren't sure about that, so I tried going over 4 - there are 8 separate CPUs listed in the resource monitor and the total CPU usage approaches 100% only when the case is decomposed for 8 processors.
However, any decomposition seems to be much slower than using just a single core. I've tried using every number of processors between 2 and 8, yet the performance always dropped.
pimpleFoam runs slower than rhoPimpleFoam Kosuke Seto OpenFOAM Running, Solving & CFD 3 May 27, 2023 14:12
Parallel UDF Segmentation fault error KevinZ09 Fluent UDF and Scheme Programming 1 January 9, 2017 05:30
my case in CFX runs in single mode but in parallel it does not gaza CFX 1 September 16, 2014 18:52
problem with mpirun (runs fine in single thread mode) Jonathan OpenFOAM Running, Solving & CFD 1 April 1, 2013 11:56
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 22:30
