February 26, 2020, 18:00 |
Blocking error
Usama
Rep Power: 6 |
Can somebody please tell me where i am making mistake in blocking of a backward facing step: I just need the mesh I will deal with grading afterwards
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (0 0 0) (110 0 0) (110 -12.5 0) (160 -12.5 0) (160 0 0) (160 100 0) (110 100 0) (0 100 0) (0 0 10) (110 0 10) (110 -12.5 10) (160 -12.5 10) (160 0 10) (160 100 10) (110 100 10) (0 100 10) ); blocks ( hex (0 1 6 7 8 9 14 15) (55 50 1) simpleGrading (1 1 1) hex (1 2 3 4 9 10 11 12) (25 7 1) simpleGrading (1 1 1) hex (1 4 5 6 9 12 13 14) (25 50 1) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet { type patch; faces ( (0 7 15 18) ); } outlet { type patch; faces ( (3 11 12 4) (4 12 13 5) ); } fixedWalls { type wall; faces ( (0 1 9 8) (1 2 10 9) (2 3 11 10) (7 6 14 15) (6 5 13 14) ); } frontAndBack { type empty; faces ( (0 7 6 1) (1 6 5 4) (2 1 4 3) (8 15 14 9) (9 14 13 12) (10 9 12 11) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // usama@usama-VB:~/OpenFOAM/usama-7/run/tutorials/incompressible/icoFoam/cavity/My_backstep_sample$ blockMesh /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-1ff648926f77 Exec : blockMesh Date : Feb 27 2020 Time : 00:12:55 Host : "usama-VB" PID : 31702 I/O : uncollated Case : /home/usama/OpenFOAM/usama-7/run/tutorials/incompressible/icoFoam/cavity/My_backstep_sample nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/usama/OpenFOAM/usama-7/run/tutorials/incompressible/icoFoam/cavity/My_backstep_sample/system/blockMeshDict" Creating block edges No non-planar block faces defined Creating topology blocks Creating topology patches Creating block mesh topology Check topology Basic statistics Number of internal faces : 2 Number of boundary faces : 14 Number of defined boundary faces : 14 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list --> FOAM FATAL ERROR: Inconsistent number of faces between block pair 1 and 2 From function void Foam::blockMesh::calcMergeInfo() in file blockMesh/blockMeshMerge.C at line 222. FOAM exiting |
February 26, 2020, 18:26 |
Error figured out
Usama
Rep Power: 6 |
The error was in numbering of block 2
it should be: hex (2 3 4 1 10 11 12 9) (25 7 1) simpleGrading (1 1 1) hope it helps some other too |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
