Sita Drost
Rep Power: 18 ![]() |
Hi all,
I'm trying to mesh a sail geometry, which I import into snappyHexMesh (OF7) from an stl-file. As the geometry has zero thickness, I'm treating it as a baffle. Even though I'm using explicit feature snapping (and the extracted edges look nice and smooth), in the final mesh the edges of my sail turn out rather badly (see attached images). What I've tried so far: - Refining the background mesh - Refining the edge mesh - Refining the surface mesh - Increasing/decreasing resolveFeatureAngle - Playing around with settings in snapControls (nSmoothPatch, tolerance, nSolveIter, nRelaxIter, nFeatureSnapIter) - And probably some more things which I can't even remember... None of these settings seem to make much of a difference though. Is there something that I'm missing/doing wrong? Any tips would be appreciated! Sita EDIT: Anyone? I'm perfectly aware that this looks like a problem that has been solved before, and that there should be answers somewhere on this forum. It's just that I can't find anything specifically on baffles, and the other answers didn't help me so far. Last edited by sita; March 18, 2020 at 09:10. |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
