[snappyHexMesh] Prblem with refinement at angle walls |
April 14, 2020, 01:27 |
felipe ortega
Rep Power: 6 |
Hello everyone,
I am working in a problem that involves heat transfer. My geometry consists in four ducts that inyect and extract hot air to a chamber. There are two inyectors and two extractors quite simples. However, they have some angle walls that i have not be able to refine well. here are some pics. 1.png 2.png 3.png 4.png 5.png My snappyHexMesh file is the next one. Code:
castellatedMesh true; snap true; addLayers false; geometry { walls.stl { type triSurfaceMesh; name walls; } inlet1.stl { type triSurfaceMesh; name inlet1; } inlet2.stl { type triSurfaceMesh; name inlet2; } outlet1.stl { type triSurfaceMesh; name outlet1; } outlet2.stl { type triSurfaceMesh; name outlet2; } castellatedMeshControls { maxLocalCells 100000; maxGlobalCells 2000000; minRefinementCells 10; maxLoadUnbalance 0.10; nCellsBetweenLevels 3; features ( { file "walls.eMesh"; level 2; } ); refinementSurfaces { walls { level (2 2); patchInfo { type wall; inGroups (walls); } } inlet1 { level (2 2); patchInfo { type patch; inGroups (inlet1); } } inlet2 { level (2 2); patchInfo { type patch; inGroups (inlet2); } } outlet1 { level (2 2); patchInfo { type patch; inGroups (outlet1); } } outlet2 { level (2 2); patchInfo { type patch; inGroups (outlet2); } } } resolveFeatureAngle 30; locationInMesh (4.0 2.0 0.5); allowFreeStandingZoneFaces true; } snapControls { nSmoothPatch 10; tolerance 1.5; nSolveIter 100; nRelaxIter 10; nFeatureSnapIter 35; implicitFeatureSnap false; explicitFeatureSnap true; multiRegionFeatureSnap true; } meshQualityControls { maxNonOrtho 90; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minVol -1e30; minTetQuality 1e-30; minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.02; minVolRatio 0.01; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; } debug 0; mergeTolerance 1e-6; When i run checkMesh, i obtain the next results. Code:
Checking geometry... Overall domain bounding box (0 -0.0500007 -0.0529237) (21.74 3.27545 0.535) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.05951e-17 2.05273e-16 1.47767e-14) OK. Max cell openness = 6.12091e-16 OK. Max aspect ratio = 46.2304 OK. Minimum face area = 2.504e-07. Maximum face area = 0.0134802. Face area magnitudes OK. Min volume = 4.22417e-07. Max volume = 0.00135733. Total volume = 41.9109. Cell volumes OK. Mesh non-orthogonality Max: 88.8062 average: 12.8578 *Number of severely non-orthogonal (> 70 degrees) faces: 3731. Non-orthogonality check OK. <<Writing 3731 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 6.10403, 24 highly skew faces detected which may impair the quality of the results <<Writing 24 skew faces to set skewFaces Coupled point location match (average 0) OK. ***Error in face tets: 184 faces with low quality or negative volume decomposition tets. <<Writing 124 faces with low quality or negative volume decomposition tets to set lowQualityTetFaces *Edges too small, min/max edge length = 0 0.132132, number too small: 28 <<Writing 28 points on short edges to set shortEdges <<Writing 66 near (closer than 2.20007e-05 apart) points to set nearPoints *There are 2716 faces with concave angles between consecutive edges. Max concave angle = 77.0543 degrees. <<Writing 2716 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.121927 average = 0.999431 *There are 110 faces with ratio between projected and actual area < 0.8 Minimum ratio (minimum flatness, maximum warpage) = 0.121927 <<Writing 110 warped faces to set warpedFaces Cell determinant (wellposedness) : minimum: 1.67588e-09 average: 11.1604 ***Cells with small determinant (< 0.001) found, number of cells: 1421 <<Writing 1421 under-determined cells to set underdeterminedCells ***Concave cells (using face planes) found, number of cells: 24745 <<Writing 24745 concave cells to set concaveCells Face interpolation weight : minimum: 0.0200923 average: 0.450171 ***Faces with small interpolation weight (< 0.05) found, number of faces: 151 <<Writing 151 faces with low interpolation weights to set lowWeightFaces Face volume ratio : minimum: 0.0413339 average: 0.801845 Face volume ratio check OK. Failed 5 mesh checks. End If someone could help me i will really appreciate it. Best regards. Last edited by flowwwww; April 14, 2020 at 10:46. |
snap controls, snappyhexmesh |
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle | FelixJJ | FLUENT | 2 | October 20, 2021 02:39 |
[snappyHexMesh] No satisfying result with feature edge refinement | Krapf | OpenFOAM Meshing & Mesh Conversion | 5 | December 13, 2019 06:59 |
[snappyHexMesh] Refinement region - distance not working | Rasmusiwersen | OpenFOAM Meshing & Mesh Conversion | 1 | May 3, 2019 06:37 |
[snappyHexMesh] snappyHexMesh Segmentation Fault | avd28 | OpenFOAM Meshing & Mesh Conversion | 11 | May 11, 2015 20:32 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
