[snappyHexMesh] Implementation of searchableCone in OpenFOAM 7 |
September 10, 2020, 11:42 |
S A
Rep Power: 6 |
I am using OF7 for my master thesis, and I deal with an injection nozzle, so I would really like to use a cone volume to generate refinements.
This is possible with OF.com (searchableCone) but not OF.org (which I am mandate to use...). I tried to implement the searchableCone code into OF.org but not successfully... Basically I copied the codes from OF.com and modifying the lines that needed to be eliminated (based on searchableCylinder.C and .H of OF.org already implemented). Then I create a symbolic link in the libmeshTools. But nothing works, obviously. I need to implement a library .so probably but this goes beyond my knowledge. It is possible because I found an old (from this year) post where @Tobermory achieved that and I was so impressed, but sadly the post do not provide enough information (really sad). Implementing searchableCone primitive in snappyHexMesh Can you help me to achieve that and let it posted for the eternity and help other people? at least the procedure... Propanotriol. |
January 15, 2021, 12:47 |
Farouk
Rep Power: 5 |
Hey!
This is probably too late, but I am posting it here for anyone else who needs it. I needed to create a trapezoidal shaped zone in 2D and implemented searchableCone in OF7 by fixing compilation errors of the source code from openfoam.com. It is mostly syntax and some classes that do not exist (such as the mag(U) normalized velocity vector class, this was easily fixed). Farouk |
openfoam7, searchablecone, searchablecylinder, snappy, snappyhexmesh |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
FGM combustion model implementation into OpenFoam | R.Mah | OpenFOAM | 1 | November 15, 2016 04:15 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
