[Commercial meshers] Small determinant cells on border |
April 15, 2022, 07:46 |
rocco attili
Rep Power: 4 |
Hello guys,
I am creating a hexa mesh on a commercial sw (BetaCAE ANSA) and applied OF strict quality criteria. However when i perform checkMesh -allGeometry a number of small determinant cells are found. I had a look on other threads but I did not find a similar case. When isolating the mentioned cells they appear to be at the border of the domain in the intersection between two faces. Their shape is perfectly tetrahedral. Attached you'll find a series of images to visualize the cells. These cells are connecting faces with different BCs (patch, symmetry...). How does checkMesh algorithm calculate the cells determinant? Is the fact that these cells have two faces on the domain border that cause a small determinant? Finally, can I proceed with the simulation with this kind of error, or it is essential to fix it? Thank you in advance! Rocco |
April 19, 2022, 06:33 |
Hi Rocco,
Indeed this is related to the cells having faces on different domain boundaries. We also have these for many of the cases we run and it is not an issue. Best Regards, Tom |
April 19, 2022, 06:38 |
#3 | |
rocco attili
Rep Power: 4 |
Thank you for the reply! So, in case of divergence of the solution I can exclude that the cause is related to these warnings? I am triyng to "unbox" the problems to find out the critical issue. Bests, Rocco |
April 19, 2022, 07:29 |
Hi Rocco,
Well in our cases it was never a problem. Not sure if there are occasions where it would be an issue, but it does not seem likely. Cheers, Tom |
April 19, 2022, 07:34 |
rocco attili
Rep Power: 4 |
[ICEM] Error in mesh writing | helios | ANSYS Meshing & Geometry | 21 | August 19, 2021 14:18 |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 07:05 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
