[snappyHexMesh] SHM Boundaryproblems with an STL-File |
November 24, 2020, 00:24 |
Rep Power: 8 |
Hello, i need your help, at my first meshing attempt with an STL-File. The STL-File ist shown below, its shape is very similar to the Dambreak tutorial. The overall lenght is about 2 m.
I do a "background" Mesh with blockMesh, all edges are 3 m long, to cover the whole STL Geometry. After that, i do the "snappyHexMesh" command. Obviously the mesh is build right. If i open up the case with parafoam, the consols shows many warnings. Code:
kai@Kai-Desktop:~/OpenFOAM/kai-7/run/tutorials_of/multiphase/interFoam/laminar/damBreak_stl/damBreak$ paraFoam I/O : uncollated --> FOAM Warning : From function virtual Foam::polyMesh::readUpdateState Foam::polyMesh::readUpdate() in file meshes/polyMesh/polyMeshIO.C at line 209 unexpected consequences. Proceed with care. --> FOAM Warning : From function Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 804 Cannot find any patch or group names matching left --> FOAM Warning : From function Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 804 Cannot find any patch or group names matching end --> FOAM Warning : From function Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 804 Cannot find any patch or group names matching front --> FOAM Warning : From function Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 804 Cannot find any patch or group names matching bottom --> FOAM Warning : From function Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 804 Cannot find any patch or group names matching top --> FOAM Warning : From function Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 804 Cannot find any patch or group names matching right --> FOAM Warning : From function virtual Foam::polyMesh::readUpdateState Foam::polyMesh::readUpdate() in file meshes/polyMesh/polyMeshIO.C at line 209 unexpected consequences. Proceed with care. Here are the results. Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-1ff648926f77 Exec : checkMesh Date : Nov 24 2020 Time : 05:59:41 Host : "Kai-Desktop" PID : 6898 I/O : uncollated Case : /home/kai/OpenFOAM/kai-7/run/tutorials_of/multiphase/interFoam/laminar/damBreak_stl/damBreak nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 // blockMesh Mesh stats points: 29791 faces: 83700 internal faces: 78300 cells: 27000 faces per cell: 6 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 27000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology left 900 961 ok (non-closed singly connected) end 900 961 ok (non-closed singly connected) front 900 961 ok (non-closed singly connected) bottom 900 961 ok (non-closed singly connected) top 900 961 ok (non-closed singly connected) right 900 961 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 -3 0) (3 0 3) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (1.29976e-16 1.46295e-16 6.22894e-17) OK. Max cell openness = 2.77556e-16 OK. Max aspect ratio = 1 OK. Minimum face area = 0.01. Maximum face area = 0.01. Face area magnitudes OK. Min volume = 0.001. Max volume = 0.001. Total volume = 27. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.10887e-14 OK. Coupled point location match (average 0) OK. Mesh OK. --> FOAM Warning : From function virtual Foam::polyMesh::readUpdateState Foam::polyMesh::readUpdate() in file meshes/polyMesh/polyMeshIO.C at line 209 unexpected consequences. Proceed with care. Time = 0.001 // snappyHexMesh Mesh stats points: 68306 faces: 194580 internal faces: 184620 cells: 63200 faces per cell: 6 boundary patches: 1 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 63200 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology CAD 9960 9962 ok (closed singly connected) Checking geometry... Overall domain bounding box (0 -2 0) (2 0 2) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.66453e-16 2.37027e-16 -3.06715e-16) OK. Max cell openness = 2.77556e-16 OK. Max aspect ratio = 1 OK. Minimum face area = 0.0025. Maximum face area = 0.0025. Face area magnitudes OK. Min volume = 0.000125. Max volume = 0.000125. Total volume = 7.9. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. I look into the tutorial, but i didnt find a way, or overread it, to transfer the boundarys to the snappyhexmesh. How can it be done ? Best regards Kai |
December 12, 2020, 09:27 |
Rep Power: 8 |
it was my fault. The STL File contains only one Patchname. I edited it with Blender and save all the parts with different Patchnames. Now it works perfectly
May 10, 2022, 07:50 |
Bo YF
i got the same errors. the reason is the named patch contains no faces in STL file.
November 2, 2023, 23:07 |
Dhea Putri
Rep Power: 2 |
how to fix it, if i use inventor for my object
November 2, 2023, 23:09 |
Dhea Putri
Rep Power: 2 |
i have the same error, and i dont know how to fix it. can you explain to me about the patch and the faces
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
