[blockMesh] BlockMesh grading calculator
Like Tree18Likes
Old   April 12, 2005, 07:55
Default BlockMesh grading calculator
Markus Hartinger
hartinger is on a distinguished road
Hi everybody,
i've written a calculator for the grading in the blockMesh format some time ago. It relates length, number of cells, total expansion ration, cell-to-cell expansion ratio, start cell size and end cell size.
Given the length and any two of the other, the remaining values are calculated.
It's a little programm, but I found it myself useful generating meshes with blockMesh.
If someone improves it, let me know
MeshSpace.tar.gz
regards
Markus
hartinger is offline   Reply With Quote
Old   April 12, 2005, 09:36
Default Actually, the grading factor i
Hrvoje Jasak
Actually, the grading factor in blockMesh is defined as the ratio of the last to first cell size, which is much better behaved that defining the number of cells and the geometric expansion ratio. I suppose we have both done the same thing :-)
Hrv
Hrvoje Jasak
Old   December 19, 2006, 00:09
Default Hi Markus, Thanks for the u
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Hi Markus,
Thanks for the utility. I found it very useful; esp. to find out the number of cells when one knows the start and end cell sizes in addition to the length.
I had to edit the Makefile to remove the reference to the bin subdirectory which does not exist. A sample of the utility usage is shown below for those who need to know how to use it:
madhavan@karmayug:~/MeshSpace$ ./MeshSpace ds de 0.58 0.000625 0.003125
Meshspace results by Markus.Hartinger@imperial.ac.uk :
Length L : 0.58
Number of cells n : 373
Total expansion ratio r : 5
Cell-to-cell expansion k : 1.00434
Start cell size ds: 0.000625305
End cell size de: 0.00312652
caduqued and lav like this.
msrinath80 is offline   Reply With Quote
Old   February 6, 2007, 04:08
Default Hi Markus Would you please
Armin Hosseinian
armin_h is on a distinguished road
Hi Markus
Would you please tel me how your calcualtor works?
i Couldent open that.
Cheers
armin_h is offline   Reply With Quote
Old   August 26, 2008, 18:29
Default I get this error with gcc 4.3.
I get this error with gcc 4.3.1 when running make.
Any idea what is wrong?
g++ -g -c MeshSpace.cpp
MeshSpace.cpp: In function 'int main(int, char**)':
MeshSpace.cpp:35: error: 'exit' was not declared in this scope
MeshSpace.cpp:38: error: 'atof' was not declared in this scope
make: *** [MeshSpace.o] Error 1
Old   September 1, 2008, 16:25
Default Problem solved. It was just a
Problem solved. It was just a question of adding:
#include <cstdlib>
to MeshSpace.cpp and TEdgeSpace.cpp
Old   July 21, 2010, 09:36
83_Ale_83's Avatar
Alessandro
83_Ale_83 is on a distinguished road
Sorry, which is the problem??
5:45 ale@alien:~/MeshSpace$ make
g++ -g -c TEdgeSpace.cpp
g++ -g -o bin/MeshSpace MeshSpace.o TEdgeSpace.o
/usr/bin/ld: cannot open output file bin/MeshSpace: No such file or directory
collect2: ld returned 1 exit status
make: *** [MeshSpace] Errore 1
83_Ale_83 is offline   Reply With Quote
Old   July 22, 2010, 07:37
David Boger
boger is on a distinguished road
If you read back a few posts, Srinath has already given the answer to this problem (and the next one you'll encounter). Delete bin/ from the Makefile, and include <cstdlib> in both .cpp files.
David A. Boger
boger is offline   Reply With Quote
Old   July 22, 2010, 08:04
83_Ale_83's Avatar
Alessandro
What a useless question I have done, I have missed the post
Thank you
Old   September 4, 2010, 17:40
Default Stupid question..
Nilesh Rane
nileshjrane is on a distinguished road
How to give the arguments to the program??? I didnt get it..
Sorry for this stupid question.
Imagination is more important than knowledge..
nileshjrane is offline   Reply With Quote
Old   September 6, 2010, 03:19
83_Ale_83's Avatar
Alessandro
Look at the third post; it's just an example
Old   September 6, 2010, 05:44
Nilesh Rane
Oh yes...i just overlooked it..i was trying meshspace value ds value de value...etc
Old   December 22, 2010, 05:02
Default Broken Link?
  #13
P.A.
blaise is on a distinguished road
I cannot download the .tar.gz file. All I get is a short html file saying that the file I was looking for was not found on the server. This is saved with a .unk file extension. Using wget http://... brings the same result.
Can anybody shed some light on this? Or send me the file via email to pascal \at\ pascal-anschau \dot\ de?
Thanks in advance!
Cheers, Pascal.
blaise is offline   Reply With Quote
Old   May 15, 2011, 12:14
la7low is on a distinguished road
Originally Posted by armin_h View Post
Hi Markus
Cheers
I think it solves the equations I posted there: http://www.cfd-online.com/Forums/ans...tml#post307694
Just rename the downloaded file to "MeshSpace.tar.gz", extract it, then it should work.
la7low is offline   Reply With Quote
Old   June 16, 2011, 13:51
Alex
bigbang is on a distinguished road
Thanks. This tools is just what I was looking for to mesh my boundary layer! Good show.
bigbang is offline   Reply With Quote
Old   August 17, 2011, 12:31
Pam
prameelar is on a distinguished road
Hi Srinath,
I am new to OpenFoam.
I need to create a mesh for channel with non linear mesh.
My node spacing is 12% increment for first 20 nodes near wall and 1.5 times viscous length scale and then 8% near the cwnter line and same on the otherside of the center line too..
I am confused how do I can take expansin ration?
Thanks in advance,
Prameela.
Pam
prameelar is offline   Reply With Quote
Old   August 17, 2011, 13:27
Alex
Hi Pam,
I would suggest first learning how to use blockMesh utility with openFOAM. You will need to separate the mesh into separate blocks for each grading.
First do a couple of the tutorials here to learn
Then use hartinger's tool to specify the grading based on your requirement.
Good luck.
Old   February 27, 2012, 04:01
Default Blockmesh
  #18
hhh
kunar
hhh is on a distinguished road
Dear Foamers,
i have xyz coordinates(that is model have 33 coumns and 225 rows in .csv file format) how i import and create blockmesh andbody have idea please let me know.
Thanks for the answer in advance!
hhh is offline   Reply With Quote
Old   April 8, 2012, 09:32
Kirill Cherniy
Slackware_user is on a distinguished road
first: are these coordinates of block vertices?
second: if so u can easyli write converter that will pull vertices of that file and create blocks, faces and edges.
if not that is not so easy.
Hint: remember that spline edges use mirror of last point for approxymation of y' in last point.
Slackware_user is offline   Reply With Quote
Old   April 9, 2012, 02:10
Default blockmesh-flapping wing
  #20
hhh
kunar
Dear Slackware_user,
thanks for your reply
first: these are the 3Dmodel coordinates generated in matlab,i have xyz coordinates of that model.for example generally people goes for cad model, same thing of that cad model but thing is i have coordinates, in matlab(that is model have 33 coumns and 225 rows xyz coordinates in .csv file format)how i can go for blockmesh.
[blockMesh] blockMesh - more control of grading crossley90 OpenFOAM Meshing & Mesh Conversion 2 December 19, 2022 15:44
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[blockMesh] blockMesh grading qepasol OpenFOAM Meshing & Mesh Conversion 0 June 25, 2014 06:24
[blockMesh] BlockMesh Grading Ambiguity: How to Get Desired y1 dancfd OpenFOAM Meshing & Mesh Conversion 6 June 4, 2014 01:04
[blockMesh] grading in the BlockMesh Astarta OpenFOAM Meshing & Mesh Conversion 1 May 23, 2011 15:39
