[mesh manipulation] topoSet boxToFace misses faces on some sides.
Old   December 3, 2020, 10:17
Default topoSet boxToFace misses faces on some sides.
Daniel Rostan
akataniel is on a distinguished road
I have a problem with topoSet missing out Faces that should be picked by boxToFace. I have a more complex gmsh-File where I want to use topoSet but reproduced my problem with a more simple case with a 3x3x3 cube with cubic elements. The size of the complete cube is 10.0x10.0x10.0 and I am trying to pick up all faces on every side of the cube later transforming it into patches to apply BCs.
At first I convert the gmsh via gmshToFoam and then apply topoSet with the following file:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name    inletFaces;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
            box (0.0 0.0 0.0)(10.0 0.0 10.0);
        name    outletFaces;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
            box (0.0 10.0 0.0)(10.0 10.0 10.0);
        name    bottomFaces;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
            box (0.0 0.0 0.0)(10.0 10.0 0.0);
        name    topFaces;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
            box (0.0 0.0 10.0)(10.0 10.0 10.0);
        name    leftFaces;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
            box (0.0 0.0 0.0)(0.0 10.0 10.0);
        name    rightFaces;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
            box (10.0 0.0 0.0)(10.0 10.0 10.0);
On the front(inlet), left and bottom side boxToFace finds all 9 Faces. But on the back(outlet), right and top side only 5 Faces are found. With modifying the box for the 3 latter ones to a 3D-Box (i.e. 10.01 - 9.99) allows to solve this problem for this easy case but not for a more complex geometry I actually want to use. I would be grateful for every hint, that allows to solve my problem.
Thank you!
akataniel is offline   Reply With Quote
Old   December 18, 2020, 00:30
Claudio Boezio
Ship Designer is on a distinguished road
Depending on the geometry complexity, you could try to use the utility autoPatch and play around with the angle option. It will automatically create patches named auto0, auto1 … autoN. You can then rename these and assign types with createPatch and createPatchDict. This has the limitation that if the geometry changes, the numbering of automatically created patches might change as well, requiring createPatchDict to be edited. But it still might save time. I believe you can also define patches by defining boxes or other matching criteria in the createPatchDict directly (if that's what you are trying to do) and you wouldn't need to use topoSet first.
Cheers, Claudio
Ship Designer is offline   Reply With Quote
Old   December 19, 2020, 12:46
Charles
Marpole is on a distinguished road
It seems to me that you are not using a box but a plane. Have you tested using something slightly different, such as below.
        name    outletFaces;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
            box (0.0 9.999 0.0)(10.0 10.001 10.0);
Charles L.
Marpole is offline   Reply With Quote
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] Layers not growing at all zonda OpenFOAM Meshing & Mesh Conversion 12 June 6, 2020 11:28
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
