[Other] extrudeMesh to get a axisymmetric 2D-geometry |
December 13, 2020, 12:21 |
Konrad Matena
Hello ,
I managed to mesh my cylinder-like geometry with blockMesh and snappyHexMesh (please see the picture attached, (0,0,0) is the center of the inlet). Since the geometry is axisymmetric regarding the x-axis, I want to perform a 2D-axisymmetric simulation. To do this I want to create a wedge out of my 3D-geometry with a angle of 4°. I want to use extrudeMesh and for the extrudeModel I am using sector. I tried a lot of different combinations of the following settings in the extrudeMeshDict: sourcePatches ? exposedPatchName ? sectorCoeffs { axis Pt ? axis ? angle 4 } but I can't manage to get the desired wedge-geometry. I looked a lot of this online and would appreciate it if someone knows what to put in the extrudeMeshDict. Thank you very much in advance! Konrad |
November 20, 2023, 23:10 |
Desh
Rep Power: 5 |
I am having the same problem, did you or anyone else can provide an explanation what sectorCoeffs { axisPt (0 0 0); axis (0 0 -1); angle 3; // For nLayers=1 assume symmetry so angle/2 on each side } are ? Thank you Update: Found this https://www.openfoam.com/documentati...1_1sector.html Last edited by dasith0001; November 21, 2023 at 00:01. Reason: added additional information |
November 22, 2023, 00:19 |
Desh
Rep Power: 5 |
If anyone else is interested making a 2D wedge mesh from 3D wedge domain.....
axisPt : this is an any point on your symmetry axis axis : is the direction of the symmetry axis, if your geometry is symmetrical around z-axis and in z+ direction, it should be (0 0 -1). If you get errors for negative cell volume try change the +/-. angle : the angle you apply get divided to two by the coordinate plane. Make your sourcePatch is on the x-y coordinate plane to get the mesh error free. |
Fill CAD Geometry | voldemort | Autodesk Simulation CFD | 0 | July 12, 2016 01:47 |
Import Deformed Geometry into Fluent | lgamble | FLUENT | 1 | February 25, 2016 13:59 |
[blockMesh] Trouble using blockMesh for axisymmetric geometry | twinturbotom | OpenFOAM Meshing & Mesh Conversion | 1 | February 8, 2016 20:59 |
finding torque in 2D Axisymmetric geometry( | bivas108 | FLUENT | 0 | February 21, 2013 02:02 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
