[snappyHexMesh] snapControls is undefined in dictionary
Like Tree2Likes
  • 2 Post By AtoHM
Old   July 13, 2023, 13:56
Question snapControls is undefined in dictionary
Jefferson Galeano
jeffer7 is on a distinguished road
Hi
I'm trying to mesh the 3D elbow with snappyHexMesh, I created an overall mesh that wraps around the elbow, I run surfaceFeatures and after applying sHM I get an error saying:
--> FOAM FATAL IO ERROR:
keyword snapControls is undefined in dictionary "/home/elbow/system/snappyHexMeshDict"
file: /home/elbow/system/snappyHexMeshDict from line 17 to line 361.
From function const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&) const
in file db/dictionary/dictionary.C at line 1008.
FOAM exiting
I already saw the syntax of snappyHexMesh, specifically in snapControls, but I can't see where the error is
Any suggestions?
Thanks in advance
jeffer7 is offline   Reply With Quote
Old   July 14, 2023, 02:07
M
AtoHM is on a distinguished road
There is a ":" instead of ";" at line 193 which probably causes it.
level    ((1e-4 1)): // distance from the surface patch-refinement level
Usually, if you get a - lets say clearly misleading - error message like that (because the key is obviously present), its related to syntax errors. If the above does not solve the problem, grab a fresh dict you know is working and add in your stuff again gradually to see where it fails.
Addition: Regarding the entries there, the comment appears to be wrong (or I do not understand it correctly): the first number is just a placeholder, the second number determines how many splits of the background mesh cells are done in the volume enclosed by the region. The size at the surface of this region is determined in the refinementSurfaces subdictionary, where you also defined (1 1) - thus get the same size and there is another syntax error there at line 140:
 level    level (1 1);
Hint #3: do not use insidePoint (0.0 0.0 0.0); . This point has to never coincide with a face or node of the mesh during the whole meshing process. It is recommended to use slightly off float numbers like 0.0142 for each component to decrease the odds of hitting a face or node during meshing.
Yann and jeffer7 like this.
AtoHM is offline   Reply With Quote
Old   July 14, 2023, 13:37
Thumbs up
Jefferson Galeano
I corrected the error and it didn't run, but when I change 'distance' to 'inside' I manage to run sHM and get the mesh,
mode inside;
level 1;
my other error must be in the 'distance' syntax I still don't understand how it works I'll keep watching the guide.
Thanks for your help
Edit: I already saw the error, I had missed an 's' in level
elbow
mode distance;
levels ((1e-4 1)); // distance from the surface patch-refinement level
Old   July 14, 2023, 15:23
M
Oh sorry, I completely overlooked the mode setting there. Of course, with distance the comment makes sense!
Old   February 29, 2024, 02:20
Kari Maru
maruusa is on a distinguished road
I am impressed with your article. The information you share will be an important document for me to learn more about this topic. fnf
maruusa is offline   Reply With Quote
error, mesh 3d, snapcontrol, snappyhesmeshdict
LEMOS InflowGenerator r_gordon OpenFOAM Running, Solving & CFD 103 December 18, 2018 00:58
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
