[blockMesh] Mesh defining with parameters
Like Tree4Likes
  • 2 Post By HPE
  • 1 Post By GerhardHolzinger
  • 1 Post By HPE
Old   February 9, 2021, 14:06
Default Mesh defining with parameters
Wowbagger's Avatar
Michael S.
Wowbagger is on a distinguished road
Send a message via Skype™ to Wowbagger
Hi everyone,
I want to simulate a kind of tubular heat exchanger and prepared the mesh via blockmesh.
Because of its symmetry I made the model as a wedge.
Maybe this is irrelevant depending my question but I get the same warning for a change in the geometry setup.
For some bigger angles I get the known (?) error below.
--> FOAM Warning : From function virtual void Foam::wedgePolyPatch::calcGeometry(Foam::PstreamBu ffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 70 Wedge patch 'symmetrie_back' is not planar.At local face at (2.925 119.75 0.102082) the normal (-0.0348784 -1.37971e-17 0.999392) differs from the average normal (-0.0348783 -3.67866e-20 0.999392) by 7.88202e-15Either correct the patch or split it into planar parts
So far so good. This should not really a problem as I read but to avoid this I use to go to really tiny angles.
All constructive data are set as parameters in the first part of the blockMeshDict file.
There comes the strange thing, I recognised that it is not a problem to do some calculation with the parametric setup but for the grading it is not possible.
I did the grading as shown below according to this file: http://www.wolfdynamics.com/wiki/mes..._blockmesh.pdf
    hex (5 7 8 9 23 25 26 27) ($ZR3 $ZL2 1) simpleGrading           // Block 3 Fluid
            //x-Achse
            ($BB $DD $EE)
            ($AA $CC 1)
            ($BB $DD $FF)
        //y-Achse
        1;
        //z-Achse
        1
But this is only possible if the FF variable is not calculated.
At this time my blockMeshDict file looks like this and it works fine.
But I would prefer to calculate the FF dependent on EE as shown in the commented lines:
    // Grading der Zellen, Ringspalt
    AA 0.2;                  // Anteil Kernbereich
    BB #calc "(1-$AA)/2";    // Bereich Grenzschicht
    CC 0.1;                  // Anteil Zellen Kernbereich
    DD #calc "(1-$CC)/2";    // Anteil Zellen Grenzschicht
    EE 4;                    // Grading Da
    FF 0.25;
//    FF #calc "(5-$EE)";    // Grading Di
//    FF #calc "pow ($EE, -1)";        // Grading Di - Berechnen geht nicht
//    FF #calc "1/($EE)";              // Grading Di - Berechnen geht nicht
If I start the meshing with one of the comment lines I get the same Warning as mentioned above (--> FOAM Warning ..... Either correct the patch or split it into planar parts) and paraFoam will close after a short time telling me "Segmentation fault (core dumped)".
So far I realised in the last few attemts that the meshing works with values for EE<2. I have no problem setting one more parameter for FF but I would like to know why this calculation is not working in that intented use. Does anyone have a clue?
Best regards
Michael
Wowbagger is offline   Reply With Quote
Old   February 9, 2021, 15:43
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
I have no idea regarding the main question (my apologies), but please use `eval` instead of `calc` to gain considerable level of speed by avoiding compilations.
Wowbagger and shizuka like this.
HPE is offline   Reply With Quote
Old   February 10, 2021, 02:29
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
I came across something similar, when creating wedge geometries along with inline calculation using blockMesh.
I could solve my problems by increasing the setting for writePrecision to 10 or higher. Note, that some mesh-generation or -processing tools will always write in ASCII, hence changing to writing in binary format will not always solve such issues.
Wowbagger likes this.
GerhardHolzinger is offline   Reply With Quote
Old   February 10, 2021, 15:15
Wowbagger's Avatar
Michael S.
Thanks HPE
I tried a few variations but later I found out that this is not working with my Foundation version OF8. Nevertheless, this and some other features I'll try in a further upcoming case...
Thanks GerhardHolzinger,
I tried but without success in my case.
I'll keep it in mind but go on with setting the FF parameter. Enough other jobs at my first case so far...
Best regards
Michael
Old   February 10, 2021, 15:20
HPE
HPE's Avatar
Would you consider to attach the blockMeshDict of yours, so that we can try to test it locally?
Old   February 10, 2021, 15:33
Wowbagger's Avatar
Michael S.
Sure, you are welcome!
Here it is:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
    R1 3;       // ri Innenrohr x
    R2 4;       // ra Innenrohr x
    R3 5;       // ri Außenrohr x
    R4 6;       // ra Außenrohr x
    L1 110;      // Länge Innenrohr y
    L2 5;      // Innenrohr bis Boden y
    L3 5;      // Bodenstärke y
    W #calc "degToRad(0.00002)"; // Winkel für z
    // Zellen in Länge
    ZL1 500; // Zellen in L1
    ZL2 30; // Zellen in L2
    ZL3 10; // Zellen in L3
    // Zellen Radial
    ZR1 20; // Innen
    ZR2 15; // Cu
    ZR3 30; // Ringspalt
    ZR4 10; // Cu
    EE 4;                    // Grading Da
    FF 0.25;
//    FF #calc "(5-$EE)"";    // Grading Di
    // Grading der Zellen, Kupfer -> Ringspalt
    GG 10;
// Alle benötigten Punkte:
    x0 0;
    y0 0;
    z0 0;
    x1 $R1;
    y1 0;
    z1 #calc "-1*sin($W)*$R1";
    x2 $R1;
    y2 $L1;
    z2 $z1;
    x3 0;
    y3 $L1;
    z3 0;
    x4 $R2;
    y4 0;
    z4 #calc "-1*sin($W)*$R2";
    x5 $R2;
    y5 $L1;
    z5 $z4;
    x6 $R3;
    y6 0;
    z6 #calc "-1*sin($W)*$R3";
    x7 $R3;
    y7 $L1;
    z7 $z6;
    x8 $R3;
    y8 #calc "$L1+$L2";
    z8 $z6;
    x9 $R2;
    y9 #calc "$L1+$L2";
    z9 $z4;
    x10 $R1;
    y10 #calc "$L1+$L2";
    z10 $z1;
    x11 0;
    y11 #calc "$L1+$L2";
    z11 0;
    x12 $R4;
    y12 0;
    z12 #calc "-1*sin($W)*$R4";
    x13 $R4;
    y13 $L1;
    z13 $z12;
    x14 $R4;
    y14 #calc "$L1+$L2";
    z14 $z12;
    x15 $R4;
    y15 #calc "$L1+$L2+$L3";
    z15 $z12;
    x16 $R3;
    y16 #calc "$L1+$L2+$L3";
    z16 $z6;
    x17 $R2;
    y17 #calc "$L1+$L2+$L3";
    z17 $z4;
    x18 $R1;
    y18 #calc "$L1+$L2+$L3";
    z18 $z1;
    x19 0;
    y19 #calc "$L1+$L2+$L3";
    z19 0;
    z20 #calc "-1*$z1";
    z21 #calc "-1*$z2";
    z22 #calc "-1*$z4";
    z23 #calc "-1*$z5";
    z24 #calc "-1*$z6";
    z25 #calc "-1*$z7";
    z26 #calc "-1*$z8";
    z27 #calc "-1*$z9";
    z28 #calc "-1*$z10";
    z29 #calc "-1*$z12";
    z30 #calc "-1*$z13";
    z31 #calc "-1*$z14";
    z32 #calc "-1*$z15";
    z33 #calc "-1*$z16";
    z34 #calc "-1*$z17";
    z35 #calc "-1*$z18";
// Alle Zylinder
geometry
    Zyl_Boden
        type searchableCylinder;
        point1 (0 $y11 0);
        point2 (0 $y18 0);
        radius $R4;
    Zyl_R4
        point1 (0 $y0 0);
        point2 (0 $y11 0);
        radius $R4;
    Zyl_R3
        point1 (0 $y0 0);
        point2 (0 $y11 0);
        radius $R3;
    Zyl_R2
        point1 (0 $y0 0);
        point2 (0 $y3 0);
        radius $R2;
    Zyl_R1
        point1 (0 $y0 0);
        point2 (0 $y3 0);
        radius $R1;
vertices
    ($x0 $y0 $z0) // 0
    ($x1 $y1 $z1) // 1
    ($x2 $y2 $z2) // 2
    ($x3 $y3 $z3) // 3
    ($x4 $y4 $z4) // 4
    ($x5 $y5 $z5) // 5
    ($x6 $y6 $z6) // 6
    ($x7 $y7 $z7) // 7
    ($x8 $y8 $z8) // 8
    ($x9 $y9 $z9) // 9
    ($x10 $y10 $z10) // 10
    ($x11 $y11 $z11) // 11
    ($x12 $y12 $z12) // 12
    ($x13 $y13 $z13) // 13
    ($x14 $y14 $z14) // 14
    ($x15 $y15 $z15) // 15
    ($x16 $y16 $z16) // 16
    ($x17 $y17 $z17) // 17
    ($x18 $y18 $z18) // 18
    ($x19 $y19 $z19) // 19
    ($x1 $y1 $z20) // 20
    ($x2 $y2 $z21) // 21
    ($x4 $y4 $z22) // 22
    ($x5 $y5 $z23) // 23
    ($x6 $y6 $z24) // 24
    ($x7 $y7 $z25) // 25
    ($x8 $y8 $z26) // 26
    ($x9 $y9 $z27) // 27
    ($x10 $y10 $z28) // 28
    ($x12 $y12 $z29) // 29
    ($x13 $y13 $z30) // 30
    ($x14 $y14 $z31) // 31
    ($x15 $y15 $z32) // 32
    ($x16 $y16 $z33) // 33
    ($x17 $y17 $z34) // 34
    ($x18 $y18 $z35) // 36
blocks
    hex (0 1 2 3 0 20 21 3) ($ZR1 $ZL1 1) simpleGrading (1 1 1)     // Block 0 Fluid Innenrohr
    hex (3 2 10 11 3 21 28 11) ($ZR1 $ZL2 1) simpleGrading (1 1 1)   // Block 1 Fluid Innenrohr
    hex (2 5 9 10 21 23 27 28) ($ZR2 $ZL2 1) simpleGrading (1 1 1)    // Block 2 Fluid Innenrohr
            //x-Achse
            ($BB $DD $EE)
            ($AA $CC 1)
            ($BB $DD $FF)
        //y-Achse
        1;
        //z-Achse
        1
    hex (4 6 7 5 22 24 25 23) ($ZR3 $ZL1 1) simpleGrading              // Block 4 Fluid Wärmeaufnahme
            //x-Achse
            ($BB $DD $EE)
            ($AA $CC 1)
            ($BB $DD $FF)
            //y-Achse
            1;
            //z-Achse
            1
    hex (1 4 5 2 20 22 23 21) ($ZR2 $ZL1 1) simpleGrading (1 1 1)     // Block 5 Kupfer Innenrohr
    hex (6 12 13 7 24 29 30 25) ($ZR4 $ZL1 1) simpleGrading ($GG 1 1)     // Block 6 Kupfer Innenrohr
    hex (7 13 14 8 25 30 31 26) ($ZR4 $ZL2 1) simpleGrading ($GG 1 1)     // Block 7 Kupfer Innenrohr
    hex (8 14 15 16 26 31 32 33 ) ($ZR4 $ZL3 1) simpleGrading ($GG $GG 1)     // Block 8 Kupfer Boden
    hex (9 8 16 17 27 26 33 34) ($ZR3 $ZL3 1) simpleGrading              // Block 9 Kupfer Boden
            //x-Achse
            ($BB $DD $EE)
            ($AA $CC 1)
            ($BB $DD $FF)
        //y-Achse
        $GG
        //z-Achse
        1
    hex (10 9 17 18 28 27 34 35) ($ZR2 $ZL3 1) simpleGrading (1 $GG 1)     // Block 10 Kupfer Boden
    hex (11 10 18 19 11 28 35 19) ($ZR1 $ZL3 1) simpleGrading (1 $GG 1)     // Block 11 Kupfer Boden
edges
boundary
// Achsensymmetrie
symmetrie_front
    type wedge;
    faces
        (0 1 2 3)
        (3 2 10 11)
        (2 5 9 10)
        (5 7 8 9)
        (4 6 7 5)
        (1 4 5 2)
        (6 12 13 7)
        (7 13 14 8)
        (8 14 15 16)
        (9 8 16 17)
        (10 9 17 18)
        (11 10 18 19)
symmetrie_back
    type wedge;
    faces
        (0 20 21 3)
        (3 21 28 11)
        (21 23 27 28)
        (23 25 26 27)
        (22 24 25 23)
        (20 22 23 21)
        (24 29 30 25)
        (25 30 31 26)
        (26 31 32 33)
        (27 26 33 34)
        (28 27 34 35)
        (11 28 35 19)
inlet
    type patch;
    faces
    (0 1 20 0)
outlet
    type patch;
    faces
    (4 6 24 22)
HotSide
    type patch;
    faces
    (14 15 31 32)
    (13 14 31 30)
    (12 13 30 29)
As you see I changed back to the #calc command because of OF8.
Thanks in advance, I have to leave for today but will be back latest at the weekend.
Best regards
Michael
Old   February 13, 2021, 13:40
Wowbagger's Avatar
Michael S.
Hi everyone,
I tried to use the OF2012 version just to see if there is a difference to OF8.
Strange things happened...
I used the blockMeshDict file as listed above and OF2012 gave me this error:
--> FOAM FATAL IO ERROR: (openfoam-2012)
Block hex (0 1 2 3 0 20 21 3) (20 500 1) simpleGrading (1(1) 1(1) 1(1)) has inward-pointing faces
4(0 3 2 1) 4(0 20 21 3)
file: /home/michel/OpenFOAM/michel-v2012/run/WL_v01-10/system/blockMeshDict.blocks at line 251.
From void Foam::blockDescriptor::check(const Foam::Istream&)
in file blockDescriptor/blockDescriptor.C at line 86.
FOAM exiting
Intentionally I increased the degree of the wedge to "degToRad(0.002)" and the meshing worked.
Also checkMesh gave that reportings:
***Zero or negative face area detected. Minimum area: 0
***Max skewness = 1e+149, 540 highly skew faces detected which may impair the quality of the results
Switching to the calculation: FF #calc "1/($EE)";
Gave me the very first warning as seen in the beginning of this thread: "Either correct the patch or split it into planar parts"
checkMesh told me:
***High aspect ratio cells found, Max aspect ratio: 8.56384e+146, number of cells 7020
***Zero or negative cell volume detected. Minimum negative volume: -5.88415e-20, Number of negative volume cells: 7020
***Number of non-orthogonality errors: 13486.
***Max skewness = 6.11703e+149, 14606 highly skew faces detected which may impair the quality of the results
Furthermore I changed "#calc" to "#eval".
Meshing seems ok and only two mesh check failed with two reports as above:
So far so good. The 540 cells should be the cells at the wedge symmetry line.
I see that there are differences between OF8 and OF2012.
This might be too many different steps listed but maybe this helps somebody...
I tried this meshing with my laptop and will try the calculation on my other machine by next week.
Am I right that the zero face and max skewness shouldn be a problem with the wedge type?
Best regards
Michael
Old   March 5, 2021, 16:45
sadsid is on a distinguished road
Is it possible to introduce stretching through a formula in blockMesh. For example, introduce stretching through the attached expression.
Any hint how to do so?
sadsid is offline   Reply With Quote
Old   March 7, 2021, 13:31
Wowbagger's Avatar
Michael S.
At the moment I still have a similar problem with angles and the "asin" function.
Maybe someone else has a hint?
Best regards
Old   March 7, 2021, 14:12
I managed to introduce stretching, but not with blockMesh. But still facing a minor issue!
Old   March 9, 2021, 11:54
Wowbagger's Avatar
Michael S.
Meanwhile I changed my workstyle to get the mesh for the calculation.
At the beginning I thought it is a good idea to do all the parametric calculation in the blockMesDict.
Meanwhile I changed the calculation to Excel.
I got my parametric values and depending on them I calculate the vertices. In the attached pic is an example. Beginning in line 13 I copy to paste in blockMesDict. For me this is easier to handle. Also debugging is easier.
Maybe this helps some other users.
Best reagrds,
Michael
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
