[snappyHexMesh] Convergent layers with different patches |
April 3, 2021, 11:14 |
Cpt. Convergence
Rep Power: 8 |
Dear all,
I am trying to mesh a wing with a pylon in snappyHexMesh but I acknowledged that when I create the layers, they do not combine in the boundaries of my 2 patches (wing_wing and wing_pylon) as you can see in the attached screenshots. Since each patch has a different name I am referring to each of them as : // Beginning of SHM dict.... layers { wing_wing { nSurfaceLayers 6; } wing_pylon { nSurfaceLayers 6; } } // Other options below.... Should I put both surfaces in the same patch so the layers merge in this corner? |
April 5, 2021, 09:33 |
M
Rep Power: 12 |
Read the available documentation on the featureAngle specified in addLayersControls.
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
Problem using AMI | vinz | OpenFOAM Running, Solving & CFD | 298 | November 13, 2023 08:19 |
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 07:49 |
Possible bug with stitchMesh and cyclics in OpenFoam | Jack001 | OpenFOAM Pre-Processing | 0 | May 21, 2016 08:00 |
[snappyHexMesh] avoiding bump on patches with no layers | student666 | OpenFOAM Meshing & Mesh Conversion | 0 | May 5, 2015 12:18 |
